Old 05-13-2005, 07:43 AM
chal7ds chal7ds is offline
Default consolidating clips correctly..pls..help...
Hey Everyone,
I am splitting up a large session into multiple parts so that i can stream it later on
in Flash.
My question is, how do you consolidate sections of the session into clips that won't sound
like they're 'cut off'. When I assemble the eventual wavs into Flash i don't want there being
any 'skips' or 'cuts' or 'fallouts'..know what i'm saying?
So how do I go about making clean clips that will be consolidated seamlessly?
any help on this issue wld be much appreciated..(my file is 7 min. long..so it will probably need a pretty divergent consolidation)
thanx...
chal7ds
Old 05-13-2005, 08:38 PM
Default Re: consolidating clips correctly..pls..help...
If I understand correctly, you want several audio clips to play seamlessly as one long clip? Ideally, you would first consolidate to one continuous file and then insert breaks(Ctrl-E) at zero-crossings(zoom way in to see the wave accurately). If you make your cuts at zero crossings, there should be no pops or clicks or anything.
Old 05-14-2005, 12:41 AM
What do you mean you would first consolidate to one continuous file? Isn't the session as it is ALREADY one continuous file? I don't understand that part.
Old 05-14-2005, 06:46 AM
spkguitar's Avatar
I think you're confused about what you need to do, or someone has led you in the wrong direction.
Consolidation is joining a number of smaller regions into one large region.
If I remember correctly, you're trying to import the output of your session into flash, but the resulting wav is too large (80MB or so) to do all at one time. In that case you would need to separate not consolidate the resulting wav output into smaller regions, and import each region separately.
I think you could also bounce the whole output file to mp3 for import into flash, it would be much smaller.
Old 05-14-2005, 08:28 AM
After edits and punchins and such on any track, that track is likely to be comprised of several regions. Consolidating makes the entire track into a single region(audio file) which is easy to export. Now if you did a Bounce to Disk and import that new track into your session, then yes, it is already a continuous file. My logic was based on working with several regions that are strung together. When you cut your continuous audio file into your 3 pieces(at zero crossings), you can doubleclick on each region and give it a new name so you can keep track of your exported files easier. I like the idea of converting to MP3 as well. If you don't have the MP3 option in protools, there are lots of other programs that can make an MP3 out of your .wav or AIFF file.
Old 05-14-2005, 12:22 PM
Brain Digger Brain Digger is offline
Albe,
How do you select or deselect current punch in takes? Ie when you consolidate, how do you pick which punch take will be included in the consolidation? What happens to the other takes that were not selected for consolidation?
Can you then insert other punch takes and re-consolidate if you made a mistake with the first punch take selection?
Hope this makes sense and actually adds to the thread.
XP Pro SP2
PTLE 7.4cs2-002R
Intel Core 2 Quad 2.4 GHz
K8V-SE Deluxe 4G DDR400
Radeon 9200SE-128M
Maxt 80G; WD 200G
CG8 200G SATA
Consolidating Clips/tracks Tampaguitar Pro Tools 11 9 12-20-2013 11:33 AM
Exporting Clips as WAVs, clips dont highlight in list gigantorbuzz Pro Tools 10 6 08-05-2013 01:07 PM
Cross fades are not between clips but at the end or beginning of clips phatbeatstudio Pro Tools HDX & HD Native Systems (Mac) 2 09-10-2012 02:08 AM
Drag Clips = Delete Clips??? Connor macOS 2 07-09-2012 07:50 PM
Editing clips without creating new clips dimebagslash Pro Tools 10 2 07-04-2012 07:24 AM
