Old 02-16-2009, 10:45 AM
woodpigeonblue woodpigeonblue is offline
Default spot mode - original time stamp? 7.4 m-pow
Hi
Ive been doing quite a bit of editing recently and frequently use spot mode to move regions to their original location. Normally it workd fine using the original time stamp button in spot mode, however, sometimes it seems not to work and gives me a bogus time stamp such as way off the screen along the timeline. This can happen any time during an editing session, working most of the time, then just not working then suddenly working again. Has anyone else had this problem? Does anyone know if this is a bug or if I am just doing something wrong which I dont know about...
Im using PT M-powered 7.4cs5
cheers!
Old 02-17-2009, 06:29 PM
lego lego is offline
Default Re: spot mode - original time stamp? 7.4 m-pow
Interesting q. When I use Spot in my LE with CPTK it just works as expected but whenever I F3click in MP I get "Out of range". Is it broken or I'm trying to get it out of its bounds?
"The Mackey Big Knob is, you press little button and they can hear through the headphones, you can say whatever you wanted to them without you having to yell." by Tad Donley
Old 02-23-2009, 08:47 AM
no-one else had issues with spot mode not giving out the correct original time stamp when spotting audio?????
Old 04-16-2009, 01:41 AM
ok after a few weeks i stumbled across a way to work round this although I'm not 100% sure why thuis method works so any explanation would be very handy.
I have found that if I have a region that has given me an incorrect original time stamp when i have tried to spot it, i simply group the region and then spot it again.. this time it works. Glad I stumbled across this but unsure why i have to group the region to get it to work?
shortcut: to original time stamp? pan4ama Tips & Tricks 14 07-03-2023 12:48 AM
Auto Spot to ORIGINAL time stamp instead of user? Maskeeper Post - Surround - Video 7 11-14-2022 09:10 AM
Spot to Original time stamp question oscarwonderboy Pro Tools 10 3 04-20-2013 04:17 AM
FCP original time stamp in OMF , how ? Heck890 Post - Surround - Video 4 04-10-2009 01:25 AM
how to spot the inpoint of a region based on original time stamp? c-post Tips & Tricks 3 02-15-2003 12:07 AM
