Old 04-15-2020, 12:40 PM
othon ribeiro othon ribeiro is offline
Default pro tools 2020 crashes when opening session
Hello friends,
every time i open a session on pro tools 2020.3 it crashes and close.
I can create a new session but after closing it (even without any plugin) when opening the same problem occurs.
I did a clean install of osx Catalina and PT 2020, and it didn't solve my problem.
Could someone help me?
Old 04-15-2020, 12:51 PM
Default Re: pro tools 2020 crashes when opening session
Hi, welcome to the community.
Does the same thing happen when you create a new session, import your old session data, save it, and then re-open the newly created session?
Old 04-15-2020, 01:06 PM
I already imported the data for the complete session, I saved the session and when I reopen the same problem happens
Old 04-15-2020, 01:30 PM
Sounds strange. If you have any 3rd party plugins installed, move them to unused folder and try again. Even a single badly behaving plugin can cause problems.
Old 04-15-2020, 02:31 PM
I moved the third party plugins and the problem continues.
I also moved all the pugins, including avid plugins to the unused folder and the same.
Pro tools 2019.12 work fine, only in 2020.3 I have this problem.
Old 04-15-2020, 02:32 PM
Sounds so strange I believe you need to contact Avid Support
Old 04-15-2020, 02:40 PM
Thanks.
I will continue researching and if I find the solution I will post here.
Old 04-16-2020, 04:00 AM
Othon:
Does your iMac have a Fusion system drive? They're not really that good for working in PT.
Old 04-16-2020, 07:01 AM
diskodonz diskodonz is offline
Same problem here. Can't open any session. Protools immediately crashes.
Mac Pro Mid2010, OSX 10.14.6, 4x SSD, protools 20.3.163
Old 04-16-2020, 11:39 AM
Originally Posted by musicman691 View Post
Othon:
no, i don't have fusion installed on my mac
Bounce to Quicktime Movie File Crashes Pro Tools in 2020.3 JRV Pro Tools 2020 6 04-19-2020 07:41 AM
Pro Tools crashes while opening session (and any backup) HELP!!! kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-12-2012 10:32 AM
Kontakt 4 crashes pro tools 8.0.4 when opening session Joel534 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-17-2010 09:46 PM
PT LE crashes upon opening session London 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-20-2006 06:39 AM
