Laptop causing some weird sound issues...
Has anyone else had any trouble with their laptop computer causing some strange hiss or noises to occur while using a mixer plugged into an Mbox?
Re: Laptop causing some weird sound issues...
Gregory D,(gdx)Gilmore. |
So if you are recording with the power cable off and just running the computer on battery power then you are not having the problem? It kind of seems like that is what it is because when the computer is doing things then you can hear the sounds changing through the headphones. I will try it. Glad to know that I am not the only one out there with the problem! Thanks!
Okay, you were right. I unplugged the power cable from the computer and the sound went away. Now, does anyone know how to correcct this little problem??? I have a Furman RP-8 that I am running the mixer and effects into and then I am running the computer power cable to the wall. Do I need to run the computer cable through the Furman with the other things to eliminate the loop? Second question...is this loop a localized thing here in my music room or if I take the Mbox/computer/mixer out to record somewhere will the loop occur from any electrical source? Just wondering..thanks guys!
I had the same problem. Runnining on battery alone solved the noise problem. This led to adding a cheapo ground lift adapter onto the laptop's 3 pronged plug. Works great.
Okay, here is what I have narrowed it down to. I unplug the power cable and the sound goes away. Nice! I record for about 20 minutes and the battery goes dead. How much power does the Mbox pull!! So, does anyone think that getting a new power cable for my computer will have any effect? Maybe my battery has gone bad...
Ground lift adapter??
Oh yeah, those are those things that everyone has a junk drawer full of!! Changes the three prong to two and then has the little metal thing that you screw onto the center screw of your outlet plate. Does anyone ever actually screw that thing on there?
Okay, now that is just wrong! Something as simple as that??? I got into my junk drawer and found the ground lift adapter. Plugged it on there and viola, no more noise. I was about to go out and spend a bunch on a new AC adapter for my computer! Thanks for the help!!!!
Automation Changes causing issues | Vagrant Producer | Windows | 1 | 12-28-2012 02:34 PM |
8.04 on xp causing plug in issues | converted | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 07-10-2010 02:31 AM |
mac software updaes causing issues? | MichaelBross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-22-2007 07:13 PM |
MBox+Laptop for production sound, Latency Issues? | gerax | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 04-26-2004 01:20 AM |
Mbox+Laptop for production sound, Latency Issues? | gerax | Post - Surround - Video | 10 | 04-24-2004 04:35 PM |
