#21
Re: 24p - 23.976 fps video & 24 fps audio
Thanks Frank. So, if I'm understanding you correctly, I bounce my master out as a 48kHz file (they need a LtRt downmix for screening in FCP with Director), and that will sync up with the FCP project, because I have done the work to a 23.976 picture in Pro Tools, which is the only key factor?
I could theoretically even give them a 22.050kHz file, and it would still sync up fine if my work had been done to the correct image frame rate!! Thanks again |
#22
FCP has an LtRt decoder?? Quote:
It does not matter what SR was used to record the audio. To stay in sync, you need to run at the same SR. You could "work" at 24 fps, but if you do not change the SR, the audio will still run to speed.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
#23
Thanks Tom, I think I'm finally getting it. When I said LtRt, I meant to say LoRo or just straight stereo.
And thanks to eveyone else too. |
#24
You're finally getting it? getting what? there is nothing to get! I'm afraid to say that this is a problem in your mind, in the real world, there is no problem at all.
#25
Well, Frank did most of the explaining. It can seem confusing. And I can kinda see where you would think that 24 related to 48K b/c 24 is half of 48. But, re-read what Frank wrote and a little of what I wrote, and I think it will become clear.
Sharing a video in same session for ADR (video in booth and video in control room) | Boogie457 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-01-2010 04:52 PM |
Video - Bobby Lombardi, Audio Product Strategist for Avid Audio at NAB 2010 | DTheone | General Discussion | 20 | 04-24-2010 06:53 PM |
Slaving a video recorder/camera to PT HD transport? Recording synced video with audio | sonicam | Pro Tools TDM Systems (Mac) | 5 | 02-18-2010 08:39 AM |
Can you do audio for video with PT LE? | jlnelson19 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-12-2009 01:43 PM |
Capturing Audio & Video w/ DC 30 + (Audio Sync Problem) | sroewe | Pro Tools TDM Systems (Mac) | 20 | 11-01-2000 01:39 PM |
