Old 02-18-2007, 09:25 AM
plastick plastick is offline
Default Soundreplacer Not Working Properly????
Hi all,
new to this forum....Im having issues with soundreplacer on my Digi 002 7.1.1 rack running on my iMac Intel Duo Core. it loads onto pro tools fine and i can even preview what is has replaced through the preview application on soundreplacer, but when I process it to a new audio track; nothing appears???? I have uninstalled it and re-installed it already. I have checked my iLok and its fine. I'm running PT 7.1.1 and its compatible...so what am I doing wrong here???? I go to my freinds house and his runs sweet, but mine no! specially went I went out and spent $495 on it!!!!!!! Help! Chris
Old 02-18-2007, 09:34 AM
Shawn Simpson Shawn Simpson is offline
Default Re: Soundreplacer Not Working Properly????
I'm beginning to think that my job is to post this response on the DUC:
Make sure you have the 'use in playlist' button enabled. Otherwise the processed file is created and placed in the regions list.
Have fun.
Old 02-18-2007, 09:42 AM
thanks shawn but it is checked. its the default for soundreplacer...
Old 02-18-2007, 10:15 AM
shawn your a genius!!!
are you sure it's enabled?
Is the 'use in playlist' button white with blue lettering?
Do you have some audio selected to process?
Is the processing status window popping up when you click process?
Have you checked your regions list to see if new regions are being created when you click process?
SoundReplacer is not working.... Raganok Pro Tools M-Powered (Mac) 0 02-27-2010 09:28 AM
SoundReplacer not working in Pro Tools 8.0 DanielEli 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-27-2009 02:33 AM
Not working properly trife 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 09-10-2008 08:40 AM
soundreplacer not working = just static :-(( jonathanplum 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-03-2008 02:43 AM
TC/E not working properly. twigstickley Pro Tools TDM Systems (Mac) 2 03-22-2005 10:12 AM
