Old 06-26-2013, 11:58 PM
werf werf is offline
Default ?How to "clean uninstall" 10.3.5 to get to 11?
I want to install PT 11. I currently have 10.3.5. So i have to "clean uninstall" 10.3.5 to install 10.3.6 before I can install 11.
When I attempt to uninstall 10.3.5, I am presented with 3 uninstall options. Which uninstall option is the "clean uninstall" option?
1) ProTools Only
2) ProTools, Avid HD Driver
3) ProTools, Avid HD Driver, Preferences, Databases and MIDI Device/Patch Settings
SiSoftware Sandra
ID
Host Name : Eccentrica
Workgroup : WERF STUDIO
Computer
Model : HP ENVY 17 Notebook PC 103C_5335KV G=N L=CON B=HP S=ENV
Serial Number : 5CD14*****
Chassis : HP Notebook
Mainboard : HP 159B
Serial Number : PCFEU01*******
BIOS : HP F.1C 10/31/2012
Intel vPro : 7.01.10.1065
Total Memory : 12GB DDR3 SO-DIMM
Processors
Processor : Intel(R) Core(TM) i7-2820QM CPU @ 2.30GHz (4C 8T 3.39GHz, 3.4GHz IMC, 4x 256kB L2, 8MB L3)
Socket/Slot : FC PGA988
Chipset
Memory Controller : HP Core (Sandy Bridge) Mobile DRAM Controller 100MHz, 2x 6GB DDR3 SO-DIMM 1.33GHz 128-bit, Integrated Graphics
Memory Module(s)
Memory Module : Samsung M471B5273DH0-CH9 4GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5)
Memory Module : Elpida EBJ81UG8BAS0-DJ-F 8GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5)
Video System
Monitor/Panel : LGD Generic PnP Monitor (1920x1080, LP173WF2-TPB2, 23.9")
Video Adapter : Radeon (TM) HD 6850M (SM5.0 575MHz, 1GB DDR5 3.6GHz 128-bit, PCIe 2.00 x16)
Graphics Processor
Compute Shader Processor : Radeon (TM) HD 6850M (575MHz, 1GB DDR5 3.6GHz 128-bit)
Compute Shader Processor : Mobile Intel(R) HD Graphics (12SP 12C 650MHz/1.3GHz, 64MB DDR3 1.33GHz/1.8GHz 128-bit, Integrated Graphics)
Storage Devices
2x WDC WD7500BPKT-60PK4T0 (1.5TB, RAID0/SATA300, SCSI-4, 2.5", 7200rpm, 16MB Cache) : 1TB (C:) (D:)
hp BDDVDRW CA30P (SATA150, BD-R, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:)
Logical Storage Devices
SYSTEM : 199MB (NTFS)
Hard Disk (C:) : 1TB (NTFS) @ 2x WDC WD7500BPKT-60PK4T0 (1.5TB, RAID0/SATA300, SCSI-4, 2.5", 7200rpm, 16MB Cache)
RECOVERY (D:) : 19GB (NTFS) @ 2x WDC WD7500BPKT-60PK4T0 (1.5TB, RAID0/SATA300, SCSI-4, 2.5", 7200rpm, 16MB Cache)
HP_TOOLS : 97MB (FAT32)
Optical Drive (E:) : N/A @ hp BDDVDRW CA30P (SATA150, BD-R, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : HP HM67 LPC Controller
Audio Device : HP Cougar Point High Definition Audio Controller
Audio Codec : Integrated Device Tech 7605
Audio Device : HP EG JUNIPER XT Audio Device [Radeon HD 5700 Series]
Audio Codec : ATI (AMD) HDMI Audio
Disk Controller : HP Mobile SATA RAID Controller
USB Controller 1 : HP Cougar Point USB Enhanced Host Controller #2
USB Controller 2 : HP Cougar Point USB Enhanced Host Controller #1
USB Controller 3 : HP Renesas Electronics USB 3.0 Host Controller
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : PDF-XChange 5.0 (2400x2400, Colour)
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : HP officejet 6200 series (1200x1200, USB, Colour)
Network Services
Network Adapter : Bluetooth Device (Personal Area Network) (Ethernet)
Network Adapter : Realtek PCIe GBE Family Controller (Ethernet)
Network Adapter : LAN9512/LAN9514 USB 2.0 to Ethernet 10/100 Adapter (Ethernet, 100Mbps)
Wireless Adapter : Intel(R) Centrino(R) Advanced-N 6200 AGN (802.11g (ERP), AES-CCMP, 144Mbps)
Power Management
Battery No 1 : Hewlett-Packard Primary 56.83Wh/4.47Ah
Operating System
Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 5.9
Old 06-27-2013, 12:20 AM
ha2dorff ha2dorff is offline
Default Re: ?How to "clean uninstall" 10.3.5 to get to 11?
I got one option only for clean install. I would go for option #1 in your case
Old 06-27-2013, 12:52 AM
danander11 danander11 is offline
Why would you want to uninstall 10 anyways?
If you use any third-party plug-ins, and except for a very few, you will not be able to use them in PT11.
Update to 10.3.6 and then install 11 normally. Both can run on the same computer, though not both running at the same time.
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Old 06-27-2013, 01:16 AM
Third party plugins is NOT uninstalled when you do a clean uninstall. Avid recommend a clean uninstall before installing 10.3.6. Read documentation
Old 06-27-2013, 02:23 AM
I guess I initially thought that OP wrote he was uninstalling 10 to install 11. Guess I read wrong.
Here I am,
Hobo Shave!
Old 06-27-2013, 02:35 AM
sunburst79 sunburst79 is offline
Do a clean uninstall of 10.3.5.
Run the 10.3.6 installer which is a full installer.
Run the the PT 11 installer and plugin updater.
I would update your iLok software first and make sure thats all working 100% before doing any upgrading and updating.
Making a backup of your 10.3.5 and 10.3.6 installs now before you install PT11 may be useful later on.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 06-27-2013, 07:49 AM
Whenever you uninstall any version of 9 or 10, select to remove the HD driver as well.
Old 06-27-2013, 08:08 AM
Searching the whole web site, these are the 2 statements I found that apply to my situation:
Co-Installing Pro Tools 10 and Pro Tools 11
Pro Tools 10.3.6 is the first version of Pro Tools 10 that supports installation on the same system with Pro Tools 11.Co-installation
support is limited to Windows 7 64-bit.
If you have an earlier version of Pro Tools installed, it is recommended that you perform a clean uninstall before installing Pro Tools
10.3.6 and Pro Tools 11.
Pro Tools 10.3.6 is a full installer
Avid recommends uninstalling your current version of Pro Tools prior to installing 10.3.6
Reinstall the Drivers for your interface after a Clean Uninstall
Based on these only 2 pieces of information I can find on the Avid web site about moving from 10.3.5 to 11, I will choose the 3rd uninstall option I noted in my initial email, hoping that's what ProTools means by a "clean uninstall".
Then I'll reinstall the M-Audio driver, then install PT 10.3.6. THEN I'll try to install PT 11. By then, PT 12 will probably be out with a whole new procedure as to how to move to that!!!......
Old 06-27-2013, 08:45 AM
thanks albee1952, i wish i would have seen your response a couple minutes ago. so option 2 is the one i SHOULD have picked. I picked door # 3 and now that computer won't even load windows and is attempting to repair itself!!!!!!!
Old 06-27-2013, 05:11 PM
zedhed's Avatar
zedhed zedhed is offline
I used option #3 with no problems. I always run a registry repair after a PT uninstall as well.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
"Clean Uninstall" Pro Tools 10 after moving over to Pro Tools 11? NBarnes21 macOS 13 02-28-2014 10:26 PM
What exactly is a "clean uninstall" ? Johnny2Laps macOS 5 09-03-2013 01:54 PM
Upgrade Instructions Say "Uninstall" - Plug-ins, too? Sean Rathman Windows 3 01-13-2013 02:04 PM
"Sticky" for Correct Uninstall-Reinstall Process for Pro Tools! RokVox macOS 28 09-26-2012 01:01 PM
A Real "Audio Regions Clean-Up" Command Needed! Jordan F. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 03-20-2002 09:54 AM
