Old 01-13-2011, 11:39 AM
DonaldM's Avatar
DonaldM DonaldM is offline
Default PT9 and the Mackie Onyx 1640i
My current set-up is PT LE 8.0cs3 MBox 2 Mini. However, I have new PC, Win-7 and want to upgrade on that to PT9. I also want to do better than the MBox 2 mini for the interface. I'm wondering if anyone knows if the Mackie Onyx 1640i can serve as the interface to replace the MBox?
I believe it can, but I want to be sure.
Thanks
Donald M
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Old 01-13-2011, 01:32 PM
caruso7r caruso7r is offline
Default Re: PT9 and the Mackie Onyx 1640i
I wish I had the answer for sure but from what I understand is that the mackie will come up as a m-audio 2626 firewire which again from what I've heard works well. I hope someone chimes in that has one and will share their experience.
John
Pro Tools 12.5
Macbook Pro & Windows 7 Ultimate 64 Bit
Old 01-13-2011, 02:56 PM
QuikDraw's Avatar
QuikDraw QuikDraw is offline
Talking Re: PT9 and the Mackie Onyx 1640i
Thanks
Donald M
I am currently using the Mackie Onyx 1640i as my PT9 interface. It works great! I can track 16 tracks simultaneously with 32 sample buffer for over an hour with no glitches! I've only tested 44.1 24-bit so far, but With my MBox 2 Mini the lowest buffer I can run reliably is 512.
PT9 does in general have some issues with ASIO drivers. It can be difficult to switch buffer sizes. You have to adjust it at the driver (outside of PT9), then adjust it in PT9, and it may take a few PT9 restarts. But then it works beautifully!
Note my system specs in my signature. I have a pretty weak system, and it still works great! Just make sure wireless and bluetooth are disabled and you should be fine.
-- Mike
- HP Spectre x360 Convertible 14t-ea100 - 2.9 GHz (5.0 Max Turbo) i7-1195G7 32GB RAM, OLED 3k x 2k, Iris Xe Onboard Graphics
- Windows 11 - PT 2021.12
- PreSonus Quantum 2 - PreSonus Studio 24c - Mackie Onyx 1640i
- Samsung T3 and T5 SSDs - Various USB2/3 and Firewire HDDs
Old 01-13-2011, 05:30 PM
QuikDraw's Avatar
Actually in PT9 it comes up as Loud ASIO. It's probably the PT8 M-Powered version where is comes up as the M-Audio 2626 Firewire. Anyway, I'm really happy with mine in PT9.
-- Mike
Old 01-13-2011, 05:46 PM
Good to know. Thanks.
John
Pro Tools 12.5
Old 01-14-2011, 05:52 AM
DonaldM's Avatar
Thanks folks! That's just what I wanted to know.
Old 03-06-2011, 01:39 PM
Becharax's Avatar
Becharax Becharax is offline
I was considering buying this thing !!!! and here I read your post ... now I am surely buying this 1640i just I didnt get a clear answer ...
1: Can I get rid of my Mbox2 and just use the 1640i as a sound card for PT9 ??
2: How many monitors can I get out of this 1640i
Waiting ....
Old 03-06-2011, 04:28 PM
Hbthyname Hbthyname is offline
Mackie have been having a lot of problems with their drivers for Windows 7.
Their forum is very useful for more information :)
Old 03-07-2011, 08:47 AM
dRead dRead is offline
Hey there!!
The Mackie Onyx 1640i is great, BUT many people have troubles with PT9, getting it work proberly!!
Check this out:
http://duc.avid.com/showthread.php?t=293860
I solved my troubles with a straight start-up procedure, as described in the above thread, and i hope that they (mackie and avid) will bring out new drivers soon, to get rid of this interface-droppings and stuff!!
@DJBechara: Look at the mackie-Homepage, there´s all the info you´d need....you can make plenty of monitor-mixes, cause you have 6 seperate aux-channels, one headphone out and one control-room out, 4 subgroup-outs, 1 mono out......
Old 03-08-2011, 07:35 AM
Becharax's Avatar
dREAD if you could help me out !! :) cause I am not being able to get the differences ...
I just want to know the main difference between the 1620i and 1640i !!
and how many monitors can I get out of each ones Please :)
Plus do they have the same built-in sound card ??
Many Thanks
Pro Tools 10 and Mackie Onyx 1640i Ri53WthTh3Fa11N Pro Tools 10 13 12-02-2013 05:32 AM
Mackie Onyx 1640i and PT 10 Stig Eliassen General Discussion 5 08-08-2012 03:13 AM
Mackie onyx 1640i kelsey macOS 2 09-08-2011 09:20 PM
PT 9.0 - Mackie Onyx 1640i and Firewire DonaldM Windows 10 07-20-2011 02:35 AM
Mackie Onyx 1640i gbwmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-17-2010 10:50 AM
