Structure- Pitch Wheel assignment?
Hey, anybody. Maybe Russ?
Do you know how to assign the pitch wheel in Structure? Actually, trying to get it to bend a lead synth sound. The mod wheel seems to be assigned. The pitch bend indicator is set for 2 up and 2 down. But the wheel won't affect the sound. Any thoughts? Thanx in advance...
"I'm not really HoboSoul™, but I play him at the DUC..." Mac Pro 12Core 3.46G (5.1) | 64G Ram OSX 10.11.6 | PTHDN/OMNI/Apogee Duet(non Avid) 10.3.6 / 11.3.1 Need mixes, mastering, guitar, keyboard or bass parts added to your tracks? Need custom songs/music written and produced for special occasions? Check out The Soundz Shop. Great work by pros with multi-platinum experience at excellent prices... |
Re: Structure- Pitch Wheel assignment?
Going to put a video up later. :)
I work with amazing people who do incredible things. Founder of the Expert Sites. |
Hey Russ.
I can appreciate that. And will definitely check it once you do. But in the meantime, how 'bout a tip?
Yeah, I already knew that. But, even while it's set, I get no response from my pitch wheel. I thought at first it might be my controller, but pitch works with any other VI I pull up. Any other ideas? Thanx, again.
What happens if you try and adjust the test tone patch that loads when you start Structure?
Same as with any patches. This is very strange, because the mod wheel works exactly as it should. Even with the sine wave patch. Just no pitch...
See post below...
And now for my ULTIMATE revelation. Apparently, my pitch wheel is not working in PT. When I quit PT and open a stand alone VI, it's fine. The same VI when I open PT, mod wheel ok, no pitch. That seems to be the case with any VI I open in PT. Is there some global setting for that I'm not aware of?
OK, Menu/Setup/MIDI/Input Filter
Then check to see that your bender isn't filtered as off. First set the filter to allow anything, then filter stuff after that works.
SampleTank Pitch Wheel | Plugs | Pro Tools TDM Systems (Mac) | 1 | 09-21-2013 09:37 AM |
Structure Free smart knob assignment questions | Gothboy | Virtual Instruments | 3 | 05-02-2008 01:35 PM |
Structure Free smart knob assignment issue | Gothboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-09-2008 05:58 PM |
Structure output assignment problems | Extreme Mixing | Virtual Instruments | 0 | 11-19-2007 02:19 PM |
Xpand! Pitch wheel assignment | Big World | Tips & Tricks | 4 | 02-09-2006 01:33 PM |
