Old 07-14-2016, 11:43 AM
theom theom is offline
Default Scale an automation lane?
I would like to make a selection on an automation lane, Pan for instance, and keep the written automation but scale it by 50%.
Say I receive a post mix and the front back automation is too aggressive on a particular track. I'd like to select the front back pan automation lane and hold a modifier key and drag mouse down to scale position of the break points. Keeping the intent but decreasing the range of the movement.
It this possible now?
Or do I need to go to IdeaScale?
Old 07-14-2016, 12:04 PM
john1192 john1192 is offline
Default Re: Scale an automation lane?
hi, are you speaking about TRIM Automation ?? it is there if you have PTHD ... not part of the Non-HD version ... or not yet !!! i still hold hope that we will receive all PT software features in all versions ...
cheers john
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 07-15-2016, 10:54 AM
johan2006 johan2006 is offline
You can use the All group, then reveal the automation lanes (easiest with Cntrl-command, left/right arrows). Go to just after the session end, and pull down all the automation using the Trim tool. On PTHD, just use Read + Trim and coalesce the changes to the tracks.
Old 07-15-2016, 07:03 PM
This is what I do currently, JoHan.
What I'd like is something like the clip gain up down by .5dB increments.
there is a keyboard shortcut for that. Control+Shift + up or down arrow.
I'd like it if this same key command worked for whatever automation lane is showing.
Old 10-30-2017, 07:58 PM
DaveGross DaveGross is offline
Been searching around for this.. Can't believe either I can't find it, or it doesn't exist. Working on a long show that was cut in Premier with a LOT of volume automation exported to me in the OMF on the music track. All I want to do is scale it to make the moves less drastic. i.e. 'compress/expand automation points by 20%' or ' raise all points lower than xx dB up by 20%'. OR..even better, a Horizontal Selection tool that will allow you to select all automation points above/below the line, then, once selected, lets you just grab and raise/lower ALL the points at the same time.
Is there really no way to do this????
Here's a screen shot of a real world example. I just want to raise all the 'bottom' automation points up to decrease the range of these music spikes that happen in-between the VO spots.
File Type: jpg Screen Shot 2017-10-30 at 9.00.50 PM.jpg (27.2 KB, 0 views)
dg
Old 10-30-2017, 10:11 PM
DontLetMeDrown DontLetMeDrown is offline
If there's a way, I'd like to know too.
Old 10-31-2017, 08:00 AM
hi Dave, i will take a look later but with the Pencil tool do anything like you are asking ???
cheers john
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 10-31-2017, 05:02 PM
vsrecord vsrecord is offline
For the shows I mix I convert volume automation to clip gain, then I use the automation lanes to scale sections. You need HD to do this. I'm used to Digital Performer where I can just highlight a section of automation and add or subtract volume. I'd like to see the same editing that's in the clip gain available in the automation lanes too
Old 11-01-2017, 10:35 AM
yes, that would be great .. i do not wish to Separate a Clip to be able to have the automation behave like that ..
ideascale it !!!
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 11-01-2017, 03:22 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
ideascale it !!!
And hopefully in the next 5 yrs or so....
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Alt+Shift+Automation-Lane-Change joachim Tips & Tricks 0 09-14-2014 09:05 AM
Volume Trim lane vs Automation Cliffy_Boy Pro Tools HDX & HD Native Systems (Mac) 12 03-06-2013 03:19 PM
No Send Pan automation lane on 9.0.3? Craig F macOS 1 04-21-2012 12:12 PM
automation bug in bypass lane Postman Post - Surround - Video 8 01-04-2012 06:20 AM
Automation lane size not remembered Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-07-2010 09:26 AM
