Old 10-22-2017, 08:31 AM
keithcstrat keithcstrat is offline
Default Bounce file length
When I bounce tracks the song length seems to be extended. In other words the song may be 3 minutes thirty seconds long but the bounce file is 4 minutes 45 seconds long. The extra time at the end is dead space. This has happened on numerous tracks I've bounced. The tracks are not run through a master fader there are 4 acoustic guitar tracks, a drum and vocal. I'm not sure why this is happening. I'm using PT 12.8 on a mac pro with Sierra 10.12.6.
Old 10-22-2017, 09:22 AM
john1192 john1192 is offline
Default Re: Bounce file length
are you an experienced or novice PT user .. just do not want to say things the wrong way and waste your time .. so disregard if this question is too simple ..
have you highlighted the section or created a timeline selection of what you want to bounce ??
sounds like the last Clip in your session is at 4 min 45 secs so the bounce is using that as your selection ..
cheers john
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 10-22-2017, 09:44 AM
Rich Breen Rich Breen is online now
Are you "committing" or doing a "bounce to disk"? With commit, you need to select whether you're committing entire tracks or edit selection (in the commit dialog). With BTD, just pay attention to your edit selection.
http://www.richbreen.com
Old 10-22-2017, 03:33 PM
I am using bounce to disk. I select the tracks I want and mute the ones I don't. I wasn't highlighting the track at all so I just went back and highlighted the tracks from the end to the beginning but the result was the same.
Old 10-22-2017, 03:44 PM
I also just noticed that the wav file is 3min 18 seconds and the mp3 is 4 min 34 seconds.
Old 10-22-2017, 04:30 PM
Inglesworth Inglesworth is offline
Bounce to Disk should be bouncing a file that is the length of your selection. So just make a seletion from where you want it to start to where you want it to end, and then bounce it. It should work just fine then. I would imagine that you must have had some clips back at about 4:15 (or whatever time it was you mentioned) in your session. They were probably on one of the tracks you muted, and therefore were inaudible in the bounce.
Old 10-22-2017, 05:04 PM
but are you making a Timeline selection of the length fo the Bounce you wish ???
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Bounce to Disk: Bounce to disk length is longer than my track on my time dijitalhorse Pro Tools M-Powered (Mac) 1 02-23-2016 06:27 AM
mp3 bounce adds to file length? bogasproductions Pro Tools TDM Systems (Mac) 14 02-05-2010 08:26 AM
File name Length ??!!?? PT 6.1 Noiz2 Pro Tools TDM Systems (Mac) 3 10-15-2003 11:57 PM
stereo BOUNCE to disk; File length differend! Fokke van Saane Pro Tools TDM Systems (Mac) 2 01-16-2001 10:09 AM
PT & File length michael c Pro Tools TDM Systems (Mac) 3 11-03-2000 06:58 PM
