MIDI Problems Multiple X Note Appearing
Hey everyone, I am sure I seen a thread somewhere on this problem but I cant seem to find it, so my apoligies if this is a repeat here
Everything was fine until I added my Axiom 49 to the MIDI controller section in peripherals. This is so I can use faders, knobs etc. But now everytime I play anything a little square note appears with an X (see here), to get rid of it I must move my original note off it and delete it it 4 times. Any help is much appreciated !
Macbook Pro 16" (2019) OS 10.15.7 | 2.4Ghz 8-Core Intel i9 | 32GB RAM |
Re: MIDI Problems Multiple X Note Appearing
This could be a couple things. The first to check is that you don't have multiple zones enabled on the Axiom - doing so will send one MIDI note for each zone.
The second would be to check your 'Default Thru Instrument' in Preferences>MIDI - try changing it to something else and see if the problem disappears. There also could be a 'dual MIDI input' problem. Are you using the USB connection, the MIDI connection or both to go to your computer? You should only use one or the other... |
Thanks for the quick response, the problem was multiple zones.
Thanks Digi/Avid
Midi 101 really missing? Set high note/low note on track's input | robinsonsdca | macOS | 4 | 11-10-2011 01:23 PM |
Midi note problems in PT8 | Daviskenn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-18-2008 05:50 PM |
EXPORT MIDI from Stryke NOTE FOR NOTE... |
riggi | Virtual Instruments | 1 | 03-10-2008 07:32 PM |
multiple outps for Kontakt not appearing in PT aux | dj_grimmace | Pro Tools TDM Systems (Mac) | 15 | 08-28-2005 12:19 PM |
"Wait for Note" Midi Timing Problems since 6.2.3 | One Track Music | Pro Tools TDM Systems (Mac) | 4 | 05-11-2004 08:25 AM |
