Re: creating stutter effect in PT
Or use AIR's Filter Gate with the filter set open and automate the bypass etc
I think there's some Presets in some of the AIR plugins, like a very tight Tremolo that offer the same Effect as well
Check w/ RussUk :) Edit: Sorry midnight - I did not read your post - ... that's the ticket.
David - MacStudio M1 - HDX II Sonnet xMacStudio - 16x16 HD i/o x 6 - PT ULTIMATE - SONOMA - ProTools Dock / S1 / Control App |
... also, sound toys tremolator...
e
ihatetyping |
[QUOTE=JC925602;1700946]You can trigger a gate with structure free. Change in duration and tempo are easier than moving automation points.
this last is quite cool can you explain, thanks |
ok sound very cool, can you explain, please, thanks a lot |
#16
It took some time, but here is an example session
Create a midi track create an instrument track with Structure Free with factory default (simple sine wave) set the Structure track output to a bus (let's call it trigger) On your vocal track add a gate with sidechain input to the trigger bus. When you play a note the gate open. It's easy to change the duration of MIDI notes, tempo, do a time stretch,... You can't quantize automation point to tempo, MIDI notes on the other hand... JC |
Stutter effect popping problem | Danny Winn | Tips & Tricks | 6 | 09-08-2013 11:40 AM |
Stutter Effect | Adam Christopher | Pro Tools 10 | 2 | 07-22-2013 12:10 PM |
Stutter effect | t0rn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-09-2009 08:36 PM |
Stutter effect | blackfader | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-16-2008 06:13 AM |
timed stutter effect...LIke tremilo but not | monkey | Tips & Tricks | 10 | 06-30-2002 03:45 PM |
