Can I record audio tracks live while midi playback is on?
Hi, I'm sure I miss some basic action here, since I always work in midi and never record audio.
I created a midi session in PT8, everything fine with my midi rtas. Then I plugged an external synth (MicroKorg) in my Mbox2Pro (Line in 1 L/R). Then I created a stereo audio track in my session.: in order to hear the synth I must choose the Spdif in on the Audio Mix, and this seems strange to me but ok. Then, if I playback the midi parts I cannot hear the synth. When I stop the playback I can hear the synth again. What have I got to do in order to hear the midi parts so that I can record the parts I play live on the synth? Thanks!! |
Re: Can I record audio tracks live while midi playback is on?
I'm confused. Is the output of the external synth analog or SPDIF? I would assume its analog on quarter inch plugs so I am baffled as to why you would need to select SPDIF. I would think that patching the external synth into a pair of line/DI inputs would allow you to hear the synth with the track record-enabled. If that works, but you can't hear when you start recording, then you maybe have Input Only monitoring selected(easy mistake). Alt-k will toggle that selection on Windows so maybe Option-K for Macs?
Thanks very much for your post. 1. I took the line out signal from my MicroKorg synth. It's analog from quarter inch, so I'm reallt baffled too. I can hear/see the signal only if I select the spdif! Is there some selector on my Mbox Pro I should check? 2. The suggestion with Input Only Monitoring worked, thank you very much! Now I still have to fix this weird spdif issue... |
maybe check your I/O window, could simply be mislabelled or something?
MacBook Pro: 16GB M1 Pro 8c Hackintosh: MacOS Catalina, i7 6700k, 32GB RAM, RX580 Pro Tools Studio, RME RayDAT PCIe http://www.liamgaughan.com |
Anyway I never changed parameters, so what I get is the default setup. Thanks for posting! |
Midi M-Audio device only audible during record or playback | davem1 | Pro Tools 9 | 5 | 02-09-2012 06:30 PM |
Loop playback with record enabled MIDI tracks | fm_xtk | Pro Tools TDM Systems (Mac) | 2 | 07-04-2009 01:30 PM |
How many Tracks for Record/Playback? | Mystere1 | Pro Tools M-Powered (Mac) | 3 | 11-04-2008 10:45 AM |
Record Live/Multiple Tracks - question | TDub | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-22-2007 02:54 PM |
No audio playback monitoring for MIDI tracks only?! Help! | Crazykiwi | Pro Tools M-Powered (Win) | 9 | 05-15-2007 12:08 AM |
