OMNI Mixer Headphones
I've had an HDN system for years but never really used the card--too much trouble to move an HD I/O from the truck to the house, and monitoring with an HD I/O suddenly becomes a nightmare compared to the 002R I used under FW400.
I've been recording more at the house, so I finally took the plunge and bought an Omni. Here's just a little RTFM encouragement for any newcomers to the box like I was/am. On the Mixer tab in Hardware Setup HP stands for HeadPhones, not High Pass. Says so right there on page 37, but took me well over an hour to figure out why I could hear iTunes on the monitors but not the phones. Onward and upward. Peter
Gypsy: PT Ultimate 2019.5, 12-core Mac Pro 3.46Ghz 64GB OS 10.14.5, HD Native, HD OMNI, 2 Artist Mix, EUCON 18.3, Presonus 32R, Studio One 4.5.1, Quad Eight preamps, Neve 3201 EQs, 2 LA-4s, Malone Design Works desk Laptop: 10.13.6 MacBook Pro 2.8 Core i7, 16G, PT 19.5 Live 9 www.remotewest.com @RemoteWest |
Re: OMNI Mixer Headphones
Oh, and one more slightly related note. On page 13 the Omni Guide says:
Either set of Optical I/O ports can also be used for two-channel Optical S/PDIF input and output I'm wondering if that's true. I hooked up the MacPro optical out to the A input, works fine. But hooked up to the B input, nothing, and no way that I can discover to switch between the two. Peter
I think an omni only has one Adat in.
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
Manual says Port B is unused for input.
However on output it mirrors port A (channels 1-8). |
The presence of the second set of optical ports is explained by the fact that the box supports the S/MUX2 and S/MUX4 protocols for higher sample rate ADAT I/O. At the base rate only the first input port is active, and the same signal appears on both output ports--this is what Christian is referring to. At twice base rate S/MUX 2 supports four channels of I/O on each port, and at four times base rate S/MUX4 supports two channels of I/O on each port.
If, however, you set the Digital 1-2 Input Format to Optical (S/PDIF) on the Main tab of the Hardware setup page, you lock out all of the ADAT I/O to the eight input/output paths. As I said above, right there on page 13 the Guide says that either set of ports can be used for two channel optical S/PDIF I/O. In real life, however, Port B seems to be locked out. I think it's a typo in the Guide. Do I get a cookie for finding it? Peter
OMNI Software Mixer Problem | dwaynedelario | Pro Tools HDX & HD Native Systems (Mac) | 20 | 06-21-2017 06:46 PM |
HD Omni + Mixer | critza | Pro Tools HDX & HD Native Systems (Mac) | 30 | 08-27-2015 02:50 AM |
HD Omni toggle between digital inputs? mixer | musicmixer04 | Pro Tools HDX & HD Native Systems (Mac) | 4 | 02-02-2015 12:53 PM |
Omni persistent mixer with 5.1 input | dj_grimmace | Post - Surround - Video | 23 | 01-28-2015 05:08 AM |
Omni internal mixer not working properly | tiagodutra | Pro Tools HDX & HD Native Systems (Mac) | 2 | 03-19-2013 11:31 PM |
