Old 10-13-2000, 08:29 PM
Corey Shay Corey Shay is offline
Default How much attenuation for center pan?
It seems to be AROUND 2.5 dB, but not EXACTLY. This concerns me somewhat. It seems that there is no way to get a mono sound to be at its original level in 2 channels unless you make another track for it and hard pan both.
This is what I did: Used signal generator and made a full scale tone with AudioSuite (track 1). Copied the tone to another track (track 2). Using AudioSuite inverted polarity on track 2. Sent both tracks out bus 1-2, panned track 1 full left, and track 2 center. Set up a mono aux input for bus 1. Played them back, and listened to bus 1, left track 1 at unity, raised the fader on track 2 until the tone seemed to disappear (+2.5 dB). Raised the level of my monitors and could still hear the tone. Quite low, but definitely there. Are there some missing numbers here?
Old 10-16-2000, 08:25 PM
TMS TMS is offline
Default Re: How much attenuation for center pan?
I too find this to be somewhat of a drag at times.
A minus 18 tone output D to D using direct out to channel one is at minus 18 on the Dat.Channel one only of course. When switched to stereo output in the prefs and outputing with the pan in the middle you lose around 3db.This means I have to pump up the VO track or whatever is center leaving me less headroom
CS
5.1 Mix Narrator Center channel Dialogue Centre or phantom Center? kd_special Post - Surround - Video 5 03-02-2011 02:53 AM
mic input attenuation swv 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-22-2009 01:36 PM
Panning center to left to right to center NoRush 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-16-2006 08:17 PM
MKH 50 attenuation Robbis Post - Surround - Video 4 05-08-2006 12:12 PM
Pan Pot Attenuation Bert Kraaijpoel General Discussion 3 03-09-2002 06:11 AM
