Old 01-27-2012, 01:00 AM
faceb faceb is offline
Default Is there a stable PT10 with UAD2 here ?
Hi everyone, I would like to know if someone runs PT10 with UAD2 without the "access violation-can't save....blabla" issue.
Because it was a problem with WinXP but it's a big problem with W7 X64 for me.
And, does anyone have the same issue without UAD2 ?
I must say that a new computer have not solve the problem.
Thank you.
Old 01-27-2012, 06:17 AM
David Lang David Lang is offline
Default Re: Is there a stable PT10 with UAD2 here ?
UAD2 6.10 working well with Win7, 32 bit tho.
David
Old 01-27-2012, 06:26 AM
lennieh lennieh is offline
pt10hd and uad2 v 6.1 works fine for me, Win7 Professional x64 SP1
Old 01-27-2012, 11:04 AM
geetarpicker geetarpicker is offline
Some days my PT10 (not HD) with my UAD quad under Win 7 @ 64 bit is stable, and some days it is not. One day I can get 6 hours straight no problems, then the next have it crash in the first 15 minutes... The consistent thing is that it always crashes during the "save" function which is extra irritating. I recently sent a note to UAD about the issue, but they replied back with the standard PT/UAD optimization settings which I'd already tried...
Old 01-31-2012, 08:09 AM
Milko71 Milko71 is offline
I work with UAD2 (Solo) and PT10 on a Windows 7 64 bits. No problems at all. Untill now it al works very stable!
Old 02-01-2012, 11:17 AM
Oddly the problems that I've heard seem specific to the quad card, mine included.
Old 02-02-2012, 06:34 AM
29CountsNY's Avatar
29CountsNY 29CountsNY is offline
I use Quad, Duo, and Solo cards all in the same system, and I have no issues at all with Win7 64bit and PT 10 or PT 10.0.1.
Running solid from day one.
www.montabonsound.com
www.29counts.com
Pro Tools HD 2019.6 | HD Native PCIe & HD Native Thunderbolt | Lynx Aurora 16 HD | HD I/O | Digi 192 | 2010 Mac Pro 12 Core 3.46ghz | macOS Mojave 10.14.4 | 48 gigs RAM | Tascam DM3200 | Crane Song Avocet II | Antelope Isochrone OCX | Universal Audio Quad & Duo | Waves Mercury + Studio Classics v10 & Abbey Road Collection
Pro Tools HD2 8.1.1 | 2 x PCIe Core Card | 2 x Digi 192 | 2009 Mac Pro Eight Core 2.26ghz
Old 02-02-2012, 05:32 PM
imdrecordings imdrecordings is offline
Make sure you only have 3 cores of your processor reserved for RTAS support.
Even though I can designate 8 cores to RTAS, 3 seems to be the magic number for using UAD2, so you should see a massive improvement once you've made the change.
Also, PT10 really only likes buffers 512 or 1024 with UAD2 on my machine
Old 02-08-2012, 12:27 PM
Thank you all for your responses,
3 cores and 1024 buffers is not working better for me.
Old 02-09-2012, 05:36 AM
29CountsNY's Avatar
I'm using 7 of the 8 cores with 99% and I have no issues.
It did take awhile to get that setting right, and every system is going to be different in this respect.
There are a lot of factors to take into consideration, bus speed, is the pci/e slot shared with something else on the motherboard?
Check the MB manual, it should list all slots, sata plugs, etc. and whether they are shared and what they are shared with. If the pci/e slot is shared with something like a USB controller, SATA controller or LAN controller it could cause issues and unstable performance.
I would look into that and try different slots on the MB if you have them.
www.29counts.com
Is PT10 stable in Lion??? VillaLobos macOS 9 07-22-2012 10:39 PM
PT10 more stable PT9? ... or about the same? Lucero del Alba Windows 9 02-09-2012 01:33 AM
PT10 HD With UAD2 Issue Lizardpoint macOS 0 01-15-2012 04:16 AM
Pt10 hdx & uad2 hiltonius macOS 14 01-09-2012 03:22 PM
Trying now to get PT9 stable with UAD2 quad GKinTN Pro Tools 9 19 01-16-2011 05:27 PM
