Old 09-02-2019, 08:15 AM
Stephen Bond's Avatar
Default Re: a plugin to check your mix in mono
Like you can believe everything you read online
Save an additional 10% off any purchase at Waves!
https://www.waves.com/r/9zsnwd
True
Old 09-09-2019, 04:29 AM
Originally Posted by Stephen Bond View Post
Pretty sure monitoring the mono component of a M/S signal is different to summing a stereo to mono?
Anyhow, in the old Digi 001 days using the Waves S1 Stereo imager on the master was the standard with the width fader at 0.
https://www.waves.com/plugins/s1-stereo-imager
Stephen
Yeah I thought that at first too, years back. Then I did some checking. The maths for mid-side is...
mid = L + R
side = L - R
When you hit the Mono button it sums the left and right together. That’s effectively the same as the mid equation. So it does indeed work out.
Old 09-09-2019, 04:37 AM
I just double checked in Pro Tools for my own peace of mind and blow a few cobwebs away!
Indeed. I stand corrected. Summing to mono using the width on the S1 Imager (or Width at 0% on the AIR Stereo Width plugin) is the same as pressing the M button on any M/S plugin.
Each saw a -6dB drop in level of my test tone from hard left to mono.
Panning the channel to centre (using the pan pot) gives whatever the Pan Depth is set to in Session setup (-3.0 dB in my case).
Stephen
Actually I didn’t think of the S1. That’s certainly another way to go. Stick an S1 at the end of the stereo bus with the width set to 0, and activate it every time you want to do a mono check.
Old 09-09-2019, 04:52 AM
Back in 80's we used to solder L+R together in Y-cable when we used subs (for mono). Then added coil and capacitor between amp and speaker (for lowpass filter). I bet this is mostly lost art nowadays...
Old 09-09-2019, 04:55 AM
Best if your monitor controller just had the mono button
Old 09-15-2019, 07:42 AM
In the 80s I was a teenager sneaking into my sister’s room and borrowing her cassette deck and I was connecting that plus my little keyboard to the stereo on the lounge room. Basically I came up with this way of layering multiple parts to make a recording.
In later years I found out this is how it all started way back when and it was commonly called “sound on sound” recording.
Man self discovery rocks.
Yeah, not many of have the luxury of one of those, though.
HTML code is On
Why check your mix in mono? KevinAllen General Discussion 29 01-28-2010 01:15 AM
does anyone know to check a mix in mono? Help??? cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-23-2008 08:07 AM
How can I Check my mix in Mono? Derekten 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-01-2008 01:57 AM
Check Mono....? danwillrock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-19-2007 04:10 AM
mono check uwehaas Tips & Tricks 4 12-07-2005 08:28 AM
