I cannot create a new session, I am not allowed to save in external fw800 drive
I am trying to create a new session on an external drive, I have done this hundreds times but now i get this warning
: cound not create new document because you d not have appropriate access privileges (-5000).. If a save on internal drive, works, how can i solve this? |
Re: I cannot create a new session, I am not allowed to save in external fw800 drive
Are you on mac or windows?
On mac try repairing disk permissions using the disk utility. Also go to workspace and make sure, the disk is record enabled.
iMac Pro - MacOS 10.14.6 --- - Pro Tools U HDN 2019.6 - Avid HD Omni + HD I/O 8x8x8 - C|24 | S3 | Dock |
There is no chance on this Earth that repairing disk permissions will solve this problem. Repairing disk permissions only solves problems on the startup volume. Permissions issues on volumes other than the startup volume will not be fixed by repairing disk permissions.
If you are using a Mac, select the volume you cannot save your sessions to and press Command+I. In the Sharing & Permissions section of that window, there is a checkbox to Ignore ownership on this volume. Is that checkbox enabled?
Please enable that checkbox and let us know what happens.
Looking for a good, portable (small/bus powered) FW800 external audio drive | MMcCraryNJ | macOS | 15 | 04-21-2013 07:15 PM |
Fusion Drive OR external USB 3 or FW800? | Dopamine | macOS | 1 | 02-18-2013 01:29 PM |
dae error with external fw800 hard drive and pt8 on mac | DejanT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-08-2010 04:47 AM |
PT will not open or create a session on external drive | lanhet | Pro Tools M-Powered (Mac) | 1 | 10-21-2008 04:36 PM |
PT wont let me create a session on external HD | barznbeats1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-10-2005 06:11 PM |
