Old 07-28-2017, 03:28 PM
indeloon85 indeloon85 is offline
Default PT 12.8 Takes FOREVER to load now
Since I updated to 12.8 (Non-hd), I've noticed that every time I open PT, it hangs up on the loading screen before trying to load any plugins. I've tried uninstall, reinstalling, clean uninstalling, reinstalling, nothing seems to help this. It usually takes about a solid 2 minutes or more to begin loading the plugins.
This can be super frustrating throughout a workday as I finding myself constantly in this scenario and continually having to Force Quit until the program loads correctly.
How can I remedy this issue? Anyone having a similar problem??
I am also on MacOS 10.12.5.
File Type: jpg Screen Shot 2017-07-28 at 3.18.00 PM.jpg (35.0 KB, 0 views)
Old 07-28-2017, 04:12 PM
dr_daw's Avatar
dr_daw dr_daw is offline
Default Re: PT 12.8 Takes FOREVER to load now
Did you do this install on a clean OS install? How much ram do you have? We have a similar MBP and I don't experience this. Try moving all plugins to the unused folder and test it. Then add them back one at a time until it hangs.
FBR recording - https://www.facebook.com/fromthebase...cordsrecording
@FBRrecording - Instagram
Rig
MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors
Old 07-28-2017, 04:25 PM
I did a clean OS install a couple months back then upgraded to 10.12.5 once certified with PT and did the upgrade to 12.8 then. That's when it began the issue. I'll try the plugin reinstall though. Thank you for your suggestion!
Old 07-28-2017, 04:35 PM
dr_daw's Avatar
Maybe before doing that, try trashing the prefs if you haven't already. But I'm guessing that either a plugin is giving you grief or something got messed up during your OS upgrade.
Rig
Old 07-29-2017, 10:07 PM
MusoPro's Avatar
MusoPro MusoPro is offline
I have a similar scenario but only when I open it for the first time after starting up my Mac. After that if I quit PT and open again it does not take long at all.
Best
Mitch
Best
Mitch
MacPro 2.44 8 Core
Mac OSX 10.10.5
PT 12.7
HD Native
SyncHD I/O
HD I/O
MIDI I/O
C24
Aja LiHi
Surround Setup
Old 07-29-2017, 10:38 PM
First make sure a you do not have antivirus crapware installed/enabled.
Trash prefs, Start Pro Tools let it finish, do not force quit. Then quit normally. Now does it start up normally?
Old 07-30-2017, 01:09 AM
JFreak's Avatar
JFreak JFreak is offline
such as windows
Janne
Old 07-30-2017, 02:44 AM
peaklimit peaklimit is offline
I have posted elsewhere that this seems to be Workspace related. Trash Workspace files and startup is as it should be. However rebuild Workspace and the slow startup happens again. BAD!!
Old 07-30-2017, 10:42 AM
K Roche's Avatar
K Roche K Roche is offline
Just a thought people.
When someone posts about a problem or issue without having their complete system info showing. (i.e easiest way is add it to your sig. line)
Then trying to offer any help is often the audio tech equivalent of herding cats.
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 07-30-2017, 10:52 AM
dr_daw's Avatar
I thought the same thing at first; but being on the mobile app Tapatalk, it doesn't show sigs. So, I clicked on the OP's name and it comes up in his/her profile. Hence, I was able to offer somewhat of a troubleshooting technique since we have similar rigs.
PS, my info is in my sig; but as you can see it doesn't show up because I'm not posting from a computer. :P
Rig
Installer takes forever stanonbass Pro Tools 12 1 04-03-2017 09:01 AM
11.3.2 Video Engine Takes FOREVER to Load Ginger Pro Tools HDX & HD Native Systems (Mac) 1 09-17-2016 10:47 AM
Sampletank takes forever to load. chazc080488 Virtual Instruments 1 08-24-2010 09:23 AM
Starting takes forever Kiwi Bruce 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 22 01-21-2004 07:01 PM
