Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 11-23-2008, 02:41 PM
spiritG spiritG is offline
Default Is there a trick to install both LE and m-powered on the same system?
When m-powered 7.3 was installed PT 7.1 LE disappeared.
Will m-powered stay there if PT LE is installed again?
Or are different versions or some other trick required to have them both (to switch to accomodate different interfaces)?
Old 11-24-2008, 09:25 AM
DigiTechSupt's Avatar
Default Re: Is there a trick to install both LE and m-powered on the same system?
http://www.digidesign.com/index.cfm?...0&itemid=24495
Avid Audio Tech Support
Support FAQ
Can't install Pro Tools 8! Clean install, new system, Vista! DJ Hellfire 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 31 01-09-2011 11:16 AM
Can I install M-Powered 7.4 and LE 8.0 on the same system? (Win XP) pcmusicpro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-12-2010 11:11 AM
cannot install m-powered 8 on mac ox 10.6.3 swervwun Pro Tools M-Powered (Mac) 3 07-10-2010 11:01 AM
can i install both m powered and LE on the same cpu? taekwon Pro Tools M-Powered (Mac) 4 10-21-2009 02:44 AM
trick for install of 3rd card into a Mac Pro? MixerGuy Pro Tools TDM Systems (Mac) 6 02-19-2009 07:30 PM
