Simple Pro Tools monitoring Question
Okay, I have some mackie hr824's directly connected to the analog outs of my 888's and a mix plus system. Whenever I want to put a plugin like an L1 ultramaximizer on my master fader, I'm forced to blast the monitor volume in order to get good input levels into the L1 (because master fader inserts are post fader). How do I avoid having to listen at such high levels? (I know there's a simple answer to this one). Do I have to route my entire mix to a aux input with an L1 insert on it and then send it back to the master outs? This seems weird to have to do, and no manuals ever seem to suggest it. Will doing that compromise quality in any way? Any advice from you pros out there? Thanks!
Re: Simple Pro Tools monitoring Question
You need an analog attenuator of some kind. A preamp, a small mixer, or even a simple potentiometer to reduce the output levelsof your 888. Your monitoring method is not exactly proper. If the 888 were designed to be directly connected to your monitors it would have a volume control. Thats what you need.
best, rich [This message has been edited by Rich Breen (edited May 12, 2001).] [This message has been edited by Rich Breen (edited May 12, 2001).]
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
Help! Probably simple Newbie Question re: Monitoring in Headphones while Recording | ETThompson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-19-2012 06:39 AM |
Simple monitoring levels setup question | Luke K | Tips & Tricks | 4 | 11-22-2009 11:23 PM |
Simple Pro Tools question?? | NortonRedhouse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-24-2009 02:05 PM |
Very simple question from new member - pro tools | SessionSinger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-01-2007 11:04 AM |
simple pro tools question - please help!! | benwoody21 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-17-2006 10:22 PM |
