Hello,
I've recorded 4 songs of a rockband last weekend in PT 7.4 HD2 TDM (96kHz-24Bit). I have over 30 tracks (most of them are mono) for each song (all WAV files). Someone else is asking if he can mix these songs on Cubase (he's using 48kHz-24 bit) My question to you guys:
What would be a nice trick to speed up this process? Thanks! ![]() |
read the freeze tracks thing here:
http://www.songphonic.com/ProToolsTutorials then do the export cheers
cheers Mike Aiton BSc (hons) Dubbing Mixer/Sound Designer BAFTA member IPS member former Post Production Expert at www.pro-tools-expert.com ------------------------------------------------------------------- www.mikerophonics.com |
![]() Quote:
make a selection of all the tracks and the range you want to consolidate (this way you´re able to consolidate more than one track at a time) name the regions, select them all again and export them as new audio-files (shift+cmd+K) - in the export dialog choose the desired samplerate and bit-resoution
Mac Pro 2010: PT12 Ultimate 2020 on High Sierra, PT10 HD3 on Mavericks, Logic X, Digital Performer, VEPro MacBook Pro: Logic X, Mainstage |
![]() Quote:
![]() Chris
![]() Quote:
![]() Quote:
It seems to work on all versions of PT 7.x and 8.x Osman
Songphonic Pro Tools Tutorials |
192 Sample Rate Convert | Touchwood Studios | Pro Tools HDX & HD Native Systems (Mac) | 1 | 08-21-2012 04:51 PM |
Sample rate conversion & consolidate increases volume?? | D'Animation | Post - Surround - Video | 1 | 02-28-2012 08:39 AM |
Sample Rate Mismatch... How to export files as regions after problem. | Dizzi45Z | Pro Tools TDM Systems (Mac) | 2 | 04-24-2010 11:17 PM |
Sample rate convert when bouncing.. | ghost22 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-04-2007 09:56 AM |
BTD only way to convert to 44.1M sample rate? | el biciclista | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 07-19-2001 04:26 PM |
