Old 02-14-2012, 02:03 PM
drumzalicious drumzalicious is offline
Default Is it my external HD???
Hey everyone. Been doing some work lately and my sessions have all been giving me 9073 errors. Things used to run perfect on PT9 after switching to 10 i occasionally would get the errors but they are getting more and more frequent now so at this point I'm wondering if its my external HD.
Computer Specs
Mid 2010 13" MacBook Pro
2.4 GHz Intel Core 2 Duo
4 GB RAM
Interface:
MBox 2 Pro
External Drive:
OWC Mercury AL Elite Pro 250 GB.
Set up is MBP = FW800/400 cable = MBox = FW 400 cable = External Drive
The disk cache on the drive is 8 MB according to OWC and I've read that it could be the problem. I have yet to be able to find what the seek time is for the drive though.
I also have a LaCie Quadra 1TB external drive that I had mainly been using for backup/storage that has a 32 MB disk cache. Would it be better for me to switch this to my main audio drive? Or would I be better off getting a USB interface so that way my drive can plug in at FW 800 speeds.
Thanks
Old 02-14-2012, 02:34 PM
plastikman plastikman is offline
Default Re: Is it my external HD???
That drive should be fine. Does it still happen if connected MBP-->HD-->Interface? That is the 'recommended' configuration.
Originally Posted by Dizzi45Z View Post
Pro Tools doesn't ever not cease to not amaze me.
Old 02-14-2012, 03:17 PM
I can't configure it like that because the MBox 2 pro doesn't support FW800. All I'll get is buffer underflowed errors
Old 02-14-2012, 04:00 PM
Should still work with your FW800-400 cable though, right? That hard drive has two FW400 ports, doesn't it?
I would have a hard time believing that OWC drive is the problem since I know a lot of folks use those and it says right on their page that they are PT qualified. Unless something changed with PT10 and it's HD cache size requirements. Have you tried testing a session using the Lacie?
Last edited by plastikman; 02-14-2012 at 04:23 PM. Reason: modification of the post
Old 02-14-2012, 05:06 PM
only one and I've tried it the other way and the MBox Pro still gives the error messages. Its the most annoying thing ever for a hard drive to have to run half speed.
At this point I'm going to just try the LaCie. I can't work on half my sessions because of this.
Why does Avid recommend external USB over external Firewire for audio drive? DJ Hellfire Pro Tools 10 10 03-29-2012 09:39 PM
External dedicated external hard drive JuanCarlos General Discussion 1 02-15-2010 03:11 PM
Backing up Audio Drive (External) and External HD Question JCWarrior Pro Tools TDM Systems (Mac) 2 04-13-2008 04:42 AM
using an external pre with the 002 Snyderman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 07-28-2004 07:27 PM
Using External A/D for 16 Bit Mix? JB3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 09-08-2002 12:33 AM
