copying automation from one file to another
Hello everyone,
Is it possible to copy automation from one PT file to another?? I have a client who has done all sorts of volume automation to a few tracks, but now wants to work from an earlier mix that doesn't have it. Any advise is welcomed. Cheers...
Le Chateau Bow Wow Recording 33 Bonnie Burn Road - 2nd Floor Watchung, NJ 07069 908.490.1444 [email protected] iMac Intel Quad 27", 6 GB RAM, Digi-002R, PT LE 8.0.5, OS 10.6.2 |
Re: copying automation from one file to another
If you show the automation(like Volume) on both tracks, you should be able to copy from one, use the up/down key(P or :) and paste. Give it a try and if it doesn't work, just close the session and DO NOT save(or select File>Revert to Saved).
Files, not tracks. He has two PT files (projects).
regards wasserwerk |
re: copying automation from one file to another
Correct, it is from 2 different session files. If it were within the same session I'd be fine.
Import the track from the other session, then copy and paste. Delete the unneeded track.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
That's the ticket. sorry I didn't get the picture the first time around
Cheers...
Nope, that didn't do it. The automation did not follow.
Any other thoughts?? Cheers...
I saw a post from a few years ago aboot using COPY SPECIAL under the EDIT menu. It allowed me to copy, but when I closed that file and and went to the new one, the 'copy' went away. Seems like a perfect time to allow 2 PT sessions to be open at the same time, me thinks.
So... I think the easiest work around is to bounce the needed tracks. The bounced tracks will, in effect, have the automation since the volume boosts and cuts will be recorded. Once bounced I can import those tracks into the proper mix file. Anyone agree?? Cheers...
What do you mean by automation didn't follow? Didn't import? Didn't paste?
Copying single tracks from one file to another new file | Room335 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-15-2008 11:55 AM |
VCA Automation not copying | JoshT | Post - Surround - Video | 3 | 07-23-2007 12:00 PM |
copying automation | CD Productions | Post - Surround - Video | 2 | 10-31-2006 10:12 PM |
Copying mix automation | beech | Pro Tools TDM Systems (Mac) | 1 | 09-25-2002 07:01 AM |
copying plug in automation | DJBorrmann | Tips & Tricks | 1 | 08-08-2002 08:00 PM |
