Old 12-09-2000, 10:47 PM
tylermg1 tylermg1 is offline
Default HP Pavillion Model w/001
I would like to purchase 001 but I just bought a HP Pavillion model and I want to know if anybody is using one of those for 001 and if you've had any problems with compatibility.I heard they might not be compatible with each other.
Thanks
Old 12-11-2000, 11:39 AM
loopmusic loopmusic is offline
Default Re: HP Pavillion Model w/001
HP aren't recommended by digidesign; although having said that; I run Logic Platinum with a Digi001 soundcard/box with no problems... my only headache is insufficient RAM. If you specifically want to run ProTools LE, the get a SCSI card & a decent sized SCSI drive otherwise things will be troublesome.
If you are familiar with your PC, goto the start menu > run > msconfig.exe and disable all of your startup programs. This will sort out the HP enough for audio by shutting down all of those irritating apps they run in the back ground.
// Disuye Records HK
// Loopmusic Productions
Old 12-11-2000, 01:40 PM
Thanks for the feedback "loopmusic", Logic Audio platinum was my second choice. Do you know if the pavilion models are compatible with Platinum, have you heard anything negative?
Thanks Again
Old 12-12-2000, 04:04 PM
TEXAS TEXAS is offline
I had a new hp 600 mhz 8670c and it would not work at all. I bought a Sony PCV-R556DS 700 mhz off of UBid.com for $1000, installed ProTools and have not had any problems. Just what has worked for me.
Old 12-13-2000, 01:22 PM
If you are running anything less than 128Mb of RAM and push your Pavilion hard (20 tracks & rapid key commands / window changes while playback) then you get a lockup & frustrating 'lack of CPU' message...
If you leave the 'System Performance' window open in Logic while doing the above; the drives/CPU are normally nowhere near to stressing out - itz just the RAM which is holding Logic back on my HP.
Get the 256Mb RAM, Promise PCI ATA100 adapter card, an IBM Deskstar 46Gb 7200rpm audio drive and I guarantee you no troubles with Logic (4.5 or higher) and Digi001.
Happy writing
hp pavillion- will it work?? stevesound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-05-2006 03:54 PM
HP Pavillion Computers steve312 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 12-14-2004 03:05 PM
HP Pavillion What Problems?????? artworkjamal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-25-2002 10:26 PM
HP Pavillion What Problems?????? artworkjamal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-25-2002 10:17 PM
pavillion ynot General Discussion 0 02-28-2001 01:50 PM
