Old 12-08-2000, 06:51 AM
Duh! Duh! is offline
Default Takes time to start recording
When I hit '3' or try to record one track by record enabling the track, marking an inpoint and pressing play with record button 'on' in the Transport window it takes about 2-3 seconds before the playback/record starts. 'Active in background" is disabled and I have tried all buffer settings.
PIII/800/256 MB. Intel 815EEA motherboard with on board sound disabled. Recording to separate IDE drive (7200 rpm-Barracuda)
Any ideas? The same does not happen on a Mac. It is instant reaction to the command
Old 12-08-2000, 11:31 AM
dave_koz dave_koz is offline
Default Re: Takes time to start recording
same thing happen to me... help us anyone ??
Old 12-08-2000, 07:17 PM
QuikDraw QuikDraw is offline
That's normal. And the larger your drive is, the longer the delay. It has to do with how much drive space PT must allocate for recording when you press record. I've been told that you can limit the total record time allocation in a setup menu somewhere to make it quicker. I've also been told that you can select an amount of time in the time ruler and that'll make it quicker.
Either of the above methods simply allows PT to allocate less space than the whole drive, allowing it to start recording more quickly.
I've found it easiest to just use "Record Pause" mode. Hit the record button as you normally do, and then hold down "Alt" as you hit the play button. It'll now be in Record Pause mode. When you hit the play button the next time, it'll start recording instantly.
Mike
-- Mike
- MacBook Pro 15.4" (9,1) - 2.3 GHz i7 16GB RAM
- OS X 10.14.1 Mojave / Windows 10 (Bootcamp) - PT running on Windows partition
- PreSonus Quantum 2
- PreSonus Studio 24c
- MBox 3 Mini
- Mackie Onyx 1640i
- Behringer X32 Producer
- PT 2018.12 (vanilla)
- Various USB2/3 and Firewire hard drives
Old 12-10-2000, 08:42 PM
Locke Locke is offline
According to the PT docs the way to fix the delay when first hitting record is to mess with the DAE buffer sizes. Go to that window and click on help for more info.
Locke
Recording takes 5 seconds to start ! ElMajdal Pro Tools TDM Systems (Win) 11 12-17-2009 03:33 AM
Matching Start Time Takes List jazzer61 Pro Tools M-Powered (Mac) 0 12-31-2007 06:47 AM
playback and recording takes ages to start undadogz Pro Tools M-Powered (Win) 2 05-21-2007 12:56 PM
It takes 40 secs to start recording..Please help!! Camilo Toledo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 09-12-2003 06:02 PM
001 recording start takes forever jtrolka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-29-2003 12:57 AM
