Old 03-03-2016, 09:29 AM
AhmadG AhmadG is offline
Default How do I fix this clock error?
I will attach the error msg I get when ever I hear this "click" sound. Pro Tools tells me its an clock error however I have no idea how to fix this...
I cant change the clock setting because I cant find the IO control in Windows 10.
I have also recorded the "click" sound. You can hear it at the 2, 6, 10 and 14 sec mark.
I use the AVID Quartet.
https://soundcloud.com/ahmadg-759889324/audio-bugg
Old 03-03-2016, 09:21 PM
Top Jimmy's Avatar
Default Re: How do I fix this clock error?
Welcome to the APAC! (Some of us still call it the DUC)
If you are using the Quartet as an audio device in Windows, don't. Go back into the Windows audio settings and change the active input and output device back to onboard audio. Someone else reported here that he had to actually disable all of the outputs and inputs from his interface in the Windows audio devices before his interface and Pro Tools got along nicely, but usually just putting Windows back on onboard audio fixes this.
If your PC has auto jack sensing and you can't choose other ins and outs, then use some dummy plugs plugged into the audio in and out jacks on the motherboard so that Windows has something else to default to instead of the Quartet. I had to use dummy plugs on a PC last year. I cut them off of some cheap old broken studio headphones that were hanging aroud just in case I needed spare parts.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.12, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 03-04-2016, 07:32 AM
The Weed's Avatar
The Weed The Weed is offline
What he said, especially making your onboard soundcard as the default for Windows sounds/audio and leaving the Quartet only for Pro Tools.
Also Windows 10 is not supported or recommended at this time by Avid for Pro Tools. Many have it working, some not.
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 03-07-2016, 04:17 AM
Thanks for the help guys. Really sucks I cant use the quartet, hope they will fix this clock issue in the future.
Old 03-07-2016, 06:50 AM
Its less a clock issue and more of a multi-client issue I have always kept my Pro Tools audio separate to avoid this kind of hardware conflict. A decent monitor/source switcher is a great addition to any studio setup. There are plenty of choices, from under $100 to a few grand, but the Presonus central Station has been in my setup for a good 7 years now. I route the optical SPDIF from my computer to it for all non-PT audio
Old 03-07-2016, 07:57 AM
The Weed's Avatar
You can use the Quartet for Pro Tools.
Cheers,
Old 08-31-2016, 03:59 AM
aside aside is offline
I too have this same error running Win10 and the Quartet. Have tried the above, no change.
Any other ideas guys?
Cheers
Error: "Problem detected with audio clock. Check that your clock source and sample... mongo_man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 28 05-01-2010 06:08 AM
Clock Error cooldude76230 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-19-2007 02:15 AM
TDM clock error #33 EL Pro Tools TDM Systems (Win) 2 05-20-2003 01:31 AM
-1107 error, or Cycle Clock Error Kyle Nordman Pro Tools TDM Systems (Mac) 1 04-21-2003 08:06 AM
dsp clock error #42 etherinfinity 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 02-01-2001 09:57 AM
