Old 10-15-2013, 07:19 AM
garnoil garnoil is offline
Default Eucon 3/1 erased my presets:(
Just installed the latest Eucon, and all my presets and pages I had made on my control touch screen are gone.
Old 10-16-2013, 02:23 AM
Default Re: Eucon 3/1 erased my presets:(
Same here. But already the 3.0 installer wiped all my soft keys. PITA.
It's beyond me why there still isn't an easy way to export/import/merge custom soft keys into an existing set of controllers.
Frank.
PTHDn 2019.6 (OSX10.14.4), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
Old 10-16-2013, 06:09 AM
Just noticed that the softkeys are there under 10 but not in 11 on the same system.
So how do I get them to PT11 without re-programming them?
Thanks,
Frank.
Old 10-16-2013, 06:30 AM
The golfer The golfer is offline
I read in another post that you can rename the xml files to make it work. I don't remember the exact post but here is a link to another one:
http://duc.avid.com/showthread.php?t=340385
Hope that solve the problem. If I can't recall my user sets I will stay for a while on PT10.
Serge Hamel
Mixer / Sound Designer
http://www.netpostproduction.com
Old 10-16-2013, 07:26 AM
Thanks for the tip. So I have to hand-rename the xml every time I switch between 10 and 11?
OK. Another reason to stay in 10 for another while
Old 10-16-2013, 09:12 AM
TimNielsen TimNielsen is offline
Aren't they saying if you take the pt10 version of that file, duplicate it and name it pt11, it'll load your soft keys and layouts?
I mean, can't you just have both files there? Yes if you make a change to one, it won't update the other one.
I haven't tried PT11 yet, so I can't test this. But try duplicating it naming it according to that thread.
Old 10-16-2013, 11:34 AM
I Didn't try it, but I would definitely agree with Tim suggestion. Duplicate then rename the file so each version of PT see his xml files.
Serge Hamel
Old 10-16-2013, 11:58 AM
aha. ok. I'll try that. thanks!
Frank.
Old 10-16-2013, 08:04 PM
Why can't Eucon sets be exported the same as I/O configs are? Every time we upgrade Eucon we may loose presets and soft keys and there is no way to prevent this? If we could just export out current set of presets and softs, we could upgrade, and then just re-import out sets.
I don't really want to to the XML thing, what if something gets corrupted or I make a mistake..can not afford downtime.
If the XML is a good option then Avid should post a "do this step by step".
Old 10-17-2013, 06:23 AM
I couldn't agree more. I am still waiting to install eucon 3.0.1 because I can't afford downtime. Once I know, I can really work back and forth in PT 10 and PT 11 while keeping all user sets, I will switch to PT11.
I spent the last 2 years creating faster userset workflows. I'm not going to drop those workflows until I am 100% sure my user sets are usable.
Serge Hamel
Eucon Windows BUG: some windows r stuck in background when Eucon running. TuckerMix Artist Series 12 07-08-2014 01:37 PM
EUCON 2_6_1 eucon discovery cant find ip klaukholm System 5 2 10-22-2011 12:01 PM
Plug in presets and libraries erased mzkguy macOS 2 08-07-2011 05:07 AM
Alert - EuCon 2.5.6 is only for Pro Tools 9 and EuCon DigiTechSupt Artist Series 11 02-24-2011 10:25 PM
Erased Session HELP Bel Pro Tools TDM Systems (Mac) 1 04-30-2001 08:58 AM
