Old 09-24-2008, 03:37 PM
GeckoMusic GeckoMusic is offline
Default Midi CC automation
Is there a way to use a Midi CC to control an automated parameter with M-Powered?
For example, I want to use the modulation wheel on my Axiom keyboard to adjust the frequency of a high pass filter.
Another similar question: Is is possible to use the amplitude of a track to control the level of an EQ? For example: Use the amplitude of the Kick drum to automate the gain of a band pass filter on the bass.
Old 09-29-2008, 12:41 PM
Jon E. Jon E. is offline
Default Re: Midi CC automation
The answer to your first question depends on whether or not your plug in supports MIDI continuous controller input. As far as I know, DigiRack plug ins do not.
The answer to your second question is yes, many if not all DigiRack plug ins support side chaining and key inputs. Page 22 of the v7.3 DigiRack plug in guide should give you a pretty good launch point. Jon E.
Old 10-02-2008, 05:28 PM
The EQ built into pro-tools does not have a side chain input.
If we are talking the standard plugins that come with Pro-Tools 7.4 the answers are really No and No?
The only plugin with a side chain that I can find is the compressor. What EQ has a side chain input for Pro-Tools?
There has to be another way besides a side chain. Can the midi controller be mapped to faders or knobs in any way?
MIDI Automation to Audio Track Automation BBKBB Pro Tools 10 6 11-28-2012 01:56 PM
Convert MIDI automation to audio automation jnash 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-21-2010 03:28 PM
Midi Automation on LE 8 lideeq 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-30-2009 02:33 AM
Automation with Midi?? MdotCash 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-05-2009 05:50 PM
Midi volume automation when there was none smlworld MIDI 0 06-07-2007 06:03 AM
