Old 07-13-2006, 03:48 PM
Chief Technician's Avatar
Default Focus Mode - M and / Keys
I am using v7.1cs8. One of our mixers has informed me that when using the M and / keys for nudging that the "next larger value" is 5 frames. He says that he cannot find either in the manual or elsewhere how to change that next larger value to 10 frames. The manual insists that the next larger value is set at 10 frames but it is not that way in the menu. He can't find anything in prefs or under any of the other menus that address this, and is skeptical that it can't be changed.
Can anyone shed any light on this for me? Corrupt prefs? Bug in cs8? Super-secret preference somewhere?
Thanks for reading!
Old 07-13-2006, 04:16 PM
Starcrash Starcrash is offline
Default Re: Focus Mode - M and / Keys
I don't know if I can shed much light, but I certainly can add to the confusion. The nudge values depend on the TC rate set in the session setup. At 23.976 and 24 FPS it's actually "6 frames" as the next increment after "1 frame." NTSC and PAL both offer "5 frames" as described by your comrade. Seems like a good way to screw yourself up if you're not careful. "Move it 10 frames? OK. Click, click. Wait that's 12 frames "
Pascal Garneau | IMDb
Old 07-13-2006, 04:52 PM
Matt Stutter Matt Stutter is offline
I think the manual is wrong? It sure used to be 10 frames in PT6, but now it appears that the values jump from 1 frame to 5 frames.
Old 07-13-2006, 06:25 PM
FajitaTone FajitaTone is offline
I noticed the same thing. In 6.4 it's 10 frames, in 6.9.3 and higher it's 5 frames. what gives?
Ray Trujillo
Freelance Audio Engineer
Old 07-13-2006, 08:26 PM
jimlongo's Avatar
jimlongo jimlongo is offline
It was changed to 5 frames a long time ago, I thought it was with v7.
It just takes a little while to get used to, I like it better now.
noise | jimlongo
Old 07-14-2006, 02:05 AM
tj_davies tj_davies is offline
I know it's not a shortcut, but you can enter whatever nudge value you would like in the nudge window.
Hope it helps.
Tim
G5 10.8.5
PT 10.3.9 HD2
www.pearls-music.com
HTML code is On
Disable some of the Command Focus Keys jumbomusicgroup Pro Tools TDM Systems (Mac) 4 10-30-2010 04:34 AM
PT 8 LE Focus keys? myke2242 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-30-2008 10:33 PM
command focus mode problem with keys balladpunk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-12-2007 05:38 PM
Command focus keys help scar97 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-26-2006 05:43 PM
Help with Digi keyboard..focus keys.. zzzcajon Tips & Tricks 4 03-02-2002 11:03 AM
