Old 06-10-2019, 11:49 AM
Ray Lyon Ray Lyon is offline
Default Re: What smaller(er) control surface for PT19?
I use a Command 8 w/ HDX, Avid 192, 10.13.6 (High Sierra) and PT 2019.5... still works after all these years since PT 6. You may need a MIDI interface, I'm using a 2005 era Avid MIDI I/O. I've seen C|8's on ebay for $300. Hope this helps!
Ray Lyon on Facebook
www.raylyon.com
• Mac Pro 5,1 flashed 2009 model 4,1
• 12-core 2.93ghz "Westmere", 64 GB RAM
• OS 10.12.6 Sierra, PT 2019.5
• One plug-in too many, but I really like FabFilter Pro-Q 3
• Avid HDX, Revive Audio modded Avid 192 I/O
• Avid MIDI I/O, Avid Command|8
• 256GB SSD, (2) 2TB ext. drive
• NVIDIA GeForce GTX 960 2048 MB
• Samsung 34" SE790C display (3440x1440), Acer 23" A231H Display
Old 06-10-2019, 01:04 PM
Funk-O-Meter Funk-O-Meter is offline
I seriously considered a Raven, but then asked around and the two friends I know that have had them both moved on to something else so I decided to try something else first.
I just found an old Digi 003 for real cheap and I'm gonna see if a good 8 fader unit will do the job or if I need to go for a 16 fader situation.
I'm considering a used Artist Mix w/ transport if the 003 doesn't work out.
Old 06-10-2019, 01:07 PM
I never liked the Command 8 for some reason. I didn't spend much time with it though. The look of the thing always turned me off for some reason and I hated the fader caps. How has it treated you over the years?
Old 06-10-2019, 09:48 PM
Haven't had any problems, motorized faders still work great, no missing pixels on display, very functional for me... funny I always thought the 003 was a bit creepy looking with the mushroom stalk knobs...
www.raylyon.com
Old 06-12-2019, 12:54 AM
Sugarnutz Sugarnutz is offline
D-Command if you can’t afford a D-Control by far. I love mine!
HD Native Thunderbolt
HD6 Accel in Magma PE6R4 Expansion Chassis
PT HD 10, 11, 12, Ultimate 2018, 2019
Cubase 9.5 Pro
Vienna Ensemble Pro 7
Icon D-Command
HD Omni
192 Analog I/O 8 in/8 out/Digtal I/O
192 Analog I/O 8 in/Digital I/O
Two 192 Digital I/O
Apogee Rosetta 800, AD16X & DA16X (All wth X-HD cards)
Antelope Zen Studio+ Thunderbolt
15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM
512 Gb Flash Drive - OS X 10.14.3
Gigabyte z390 Designare
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
MacOS 10.14.5 Mojave
GIGABYTE GA-Z97X-UD7 TH
Intel Core i7-4790K 4.4 GHz
32 GB of DDR3 1600
EVGA GTX 760 Video Card
OS X 10.13.6 High Sierra & Win 7 Pro 64 bit
Dynaudio BM5 Mk III
B&W 604 s2
800W 15" Ported Subs
McIntosh MC-7106 Bridged ~ B&W
Hafler P7000 "Diablo" ~ Subs
Old 06-14-2019, 07:37 PM
xrekcor's Avatar
xrekcor xrekcor is offline
Originally Posted by 1m1 View Post
Depending on what you want to do with the control surface, there are some apps for iPad and Android that are controllers. I used one for awhile with my Kindle Fire called TouchDAW that was pretty good. I only needed it for the big counter display, didn't use it for fader control, but it did have that. The app is no longer being developed I don't think but maybe it's still available. It was a whopping $5 to purchase.
Just finish setting my iPad up and EuControl the new version looking really nice or just seems to run and sync better. Haven’t used it for a while well since updating to 2019.5 some weeks back, but need to use it today. But this new version definitely seems more solid same with 2019.5. Would love to have my TF5 talk to EuControl and use that as a control surface..... if ya listening Yamaha
Rob
MBP 15” 2018 macOS Mojave 10.14.5 Touch Bar and ID
Pro Tools 2019.6-23.#, Cubase 9.5, Yamaha TF5, UR44, BEHA4700
........and a bowl of M&M's
Old 06-15-2019, 07:51 PM
If $1K is top of your budget, take a look at Faderport16(Presonus). I ran the original faderport on 3 systems and it actually covered a lot of ground(even on a rig that ran a C24 because I really prefer transport on the left). Currently using a Behringer X-Touch ONE but will probably sell it and get the new Faderport. Biggest reason here is because the Behringer doesn't seem to have any way to select automation modes on the selected channel(even the old faderport can do this).
I also had the 003 for a few years, but really only needed the transport buttons. Later on I moved to an Artist MIX and Transport, but swapped the Transport for the old faderport(Transport had too many buttons that I never used). After having the Artist MIX for 3 years, I found I just didn't need it(but your work flow may be different)
I also like the S3(but not the price) and am hoping for something new from Avid, Maybe an S1 and expanders to replace the old Artist series
Old 06-16-2019, 12:53 AM
Mike Thornton's Avatar
Mike Thornton Mike Thornton is offline
The Faderport 16 would also get my vote. Read our review of the Faderport 8 with Pro Tools.
Hope that helps,
Mike
Mike Thornton MIPS
Audio Meister and Editor of Pro Tools Expert
www.pro-tools-expert.com
Old 06-16-2019, 11:11 AM
Eric Lambert's Avatar
This would be my recommendation. Just make sure it's the updated black version and not the original silver iterations -- those no longer work with modern versions of ProTools (forced retirement by Avid).
Old 06-16-2019, 11:33 AM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is online now
I have an early silver one. It took the latest firmware and works perfectly with PT 2019.5!
Bob's room 615 562-4346
Georgetown Masters 615 254-3233
Interview
Artists are the gatekeepers of truth! - Paul Robeson
003 control surface (As audio) & control 24 as surface crizdee ProControl, Control|24, Command|8 7 01-04-2016 12:30 PM
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 12:51 AM
D-Control Es32 Control Surface No Sound from Headphone outputs mark007 Pro Tools TDM Systems (Mac) 0 02-08-2012 07:03 PM
smaller foot control SloeGin Eleven Rack 36 07-18-2011 06:37 AM
Mackie Control Universal or Tascam 1082 for control surface? anders Pro Tools TDM Systems (Mac) 5 05-28-2007 06:12 AM
