Old 10-09-2011, 10:52 PM
zachbot zachbot is offline
Default ProTools 9.0.5, iLok issues, Digi 003R+ issues
I am in dire straights.
I have been happily using my Protools rig for weeks and 3 weeks ago I get an "unable to initialize ASIO device" error meaning my Digi 003R+ was not being seen by PT9 ? I updated all the drivers, checked my settings, rebooted and tried again. Nothing. I uninstalled Protools9, reinstalled my original PT8, then installed my PT9 cross grade, then updated PT9, now I get an error that my iLok needs to be updated, ok. I have downloaded the update from iLok 3x and ran the installer 3x, and I continue to get the same error, I can't even launch PT9 to see if my Digi 003 is working?
I can't believe that it is so difficult to contact AVID about these type of issues, I just want there to be some one I can email to get a little help. I have been a supporter of AVID through all the recent changes, but I am starting to get frustrated.
Has something changed recently, w/ Windows? or Digi? or iLok?
Old 10-09-2011, 11:41 PM
zedhed's Avatar
zedhed zedhed is offline
Default Re: ProTools 9.0.5, iLok issues, Digi 003R+ issues
It appears to me that most of the 003R problems like this are Firewire connectivity related. It was certainly that when I first got my 003R.
I was trying to plug the firewire cable straight into my motherboard which as it turned out had an incompatible chipset with PT. I installed a Firewire card into my computer (Oxford chipset, Texas Instruments controller) and it worked.
I usually re-install iLok driver straight after a clean PT install.
BTW, once you get it working properly, I found that my system plays nicely with PT when I Turn on the 003 (& any other outboard gear) then boot computer up. When finished shutdown computer then turn hardware off. Before I wasn't doing this and I would get random problems with drivers not communicating properly.
Too much blood in my drugstream
Gigabyte X99 SOC Force Mobo Bios vF6d
Intel Core i7 5930k socket 2011 v3 @ 3.50GHz
32GB DDR4 Crucial RAM
System: Samsung M.2NVME SSD 960 Evo
Record: Samsung M.2NVME SSD 960 Evo
Samples: Samsung SATAlll SSD 840 Pro
Storage: 2x Samsung SATAlll SSD 840 Pro
EVGA GeForce GTX 750 Graphics
PT 11HD (v11.2.1) Omni s/pdif w Eleven Rack
HD 96I/O
Win 8.1 Pro
Old 10-10-2011, 09:52 AM
I am using a FireWire 800 card on my laptop, the 400 wasn't fast enough to do multiple tracks while the system was working. My biggest issue right now is the iLok drivers, PT says I need to update the software, which I have done multiple times, but I keep getting the same initial error.
I am planning on scrubbing the whole instal tonight and starting over (yet again).
Old 10-10-2011, 12:33 PM
This message, "unable to initialize ASIO device" has nothing to do with the iLok, so maybe there are multiple issues at play. Sometimes a fresh install is the best solution(and avoid 9.0.5 for now). Also, sometimes changing the firewire driver can help(for me, the Legacy driver did NOT work, bu the TI driver works fine). Posting a Sandra report might get other advice as well
Help us Help You - READ THIS Before Posting!
Old 10-11-2011, 04:32 PM
zedhed's Avatar
Yes this did the trick for me also.
Whilst connected to Internet, Control Panel>Device Manager>IEEE1394 Bus Host Controllers>Double click controller>Driver Tab>Update Driver (Select Automatically). Repeat for all IEEE1394 controllers.
If you have the right F/W chipset you should get a Texas Instruments driver installed automatically.
HD 96I/O
Win 8.1 Pro
Old 10-12-2011, 07:54 PM
WOW still no love...I have uninstalled Protools, 2x. now I am trying to install LE8 from the disc on my PC and it stalls out and tells me there is no disc inserted!!! I can see the disc in the Windows Explorer window. I bought LE8 and cross graded to PT9.
I believe at this point that it may be an issue with my laptop. I have been running PT9 on this machine for 6 months with no issues now out of nowhere, I can not work on anything.
Old 10-12-2011, 08:19 PM
SiSoftware Sandra
Computer
Model : Dell Studio 1749
Workgroup : WORKGROUP
Host Name : Zachbot-PC
User : Zachbot
Processor
Model : Intel(R) Core(TM) i5 CPU M 520 @ 2.40GHz
Speed : 2.53GHz
Cores per Processor : 2 Unit(s)
Threads per Core : 2 Unit(s)
Type : Mobile, Dual-Core
Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing
L2 On-board Cache : 2x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
L3 On-board Cache : 3MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 4 threads sharing
Computer
Platform Compliance : Intel Centrino Mobile Technology
Mainboard : Dell 029DYC
BIOS : Dell A05 07/14/2010
Bus(es) : PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 5.68GB DDR3 SO-DIMM
Chipset
Model : Dell Core (Auburndale/Havendale) DRAM Controller
Front Side Bus Speed : 1x 133MHz (133MHz)
Total Memory : 6GB DDR3 SO-DIMM
Shared Memory : 130MB
Channels : 2
Memory Bus Speed : 2x 532MHz (1GHz)
Memory Module(s)
Memory Module : Samsung M471B5273CH0-CH9 4GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5)
Memory Module : Hynix (Hyundai) HMT325S6BFR8C-H9 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5)
Video System
Video Adapter : Intel(R) HD Graphics (12 SM4.0 767MHz, 256MB DDR3 2x533MHz 128-bit, Integrated Graphics)
Graphics Processor
Storage Devices
TOSHIBA MK5056GSY (500.1GB, SATA300, 2.5", 7200rpm, 16MB Cache) : 466GB (C:) (P:) (Y:)
TSSTcorp DVD+/-RW TS-T633C (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 7GB (D:)
DTSOFT BDROM () : N/A (E:)
Logical Storage Devices
RECOVERY (Y:) : 15GB (NTFS) @ TOSHIBA MK5056GSY (500.1GB, SATA300, 2.5", 7200rpm, 16MB Cache)
OS (C:) : 451GB (NTFS) @ TOSHIBA MK5056GSY (500.1GB, SATA300, 2.5", 7200rpm, 16MB Cache)
Pro Tools LE (D:) : 7GB (CDFS) @ TSSTcorp DVD+/-RW TS-T633C (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Optical Drive (E:) : N/A @ DTSOFT BDROM ()
Peripherals
LPC Hub Controller 1 : Dell HM55 LPC Interface Controller
Audio Device : Dell P55/PM55/3400 High Definition Audio
Audio Codec : Integrated Device Tech 7675h
Disk Controller : Dell P55/PM55/3400 4 port SATA AHCI Controller
Disk Controller : Dell O2Micro Integrated MMC/SD controller
USB Controller 1 : Dell P55/PM55/3400 USB2 Enhanced Host Controller
USB Controller 2 : Dell P55/PM55/3400 USB2 Enhanced Host Controller
FireWire/1394 Controller 1 : Dell 10F7h
SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : Xerox Phaser 8550DT PS (600x600, Colour)
Printer : Send To Microsoft OneNote 2010 Driver (1200x1200, Colour)
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : EPSON Artisan 800 Series (360x360, Colour)
Printer : Adobe PDF Converter (4000x4000, Colour)
Network Services
Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 100Mbps)
Wireless Adapter 1 : Intel(R) Centrino(R) Advanced-N 6200 AGN
Power Management
Mains (AC) Line Status : On-Line
Battery No 1 : 100%
Operating System
Windows System : Microsoft Windows 7 Home 6.01.7600
Platform Compliance : x64
Windows Experience Index
Current System : 4.7
[IMG] code is Off
Mbox Gain Issues and Protools Issues (Bounce to Disk and Knob/Pot adjustments) Lucky Bastard Getting Started 6 01-16-2014 03:29 PM
ilok issues - ProTools 9 crossgrade LE (Please install the iLok Client Software) pauledwards Windows 3 09-10-2013 04:02 PM
Protools 9 and ilok portability issues. cdavis6406 Pro Tools 9 3 11-04-2010 07:11 PM
Issues with 003R The Oxygen Kiosk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-28-2010 01:46 PM
Serious issues with 003R macdeath 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-16-2007 07:46 AM
