Old 08-30-2020, 03:54 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: 192 i/o issue
If you power it up and feed WC from loop sync (this is just normal 1X wordclock signal) out to some other digital box, does it take lock?
Other than that (and juggling the ribbon connectors so that they have clean connections) I must assume motherboard has some sort of failure that is too expensive to fix.
Janne
Old 08-30-2020, 07:39 AM
groovebrother groovebrother is offline
unfortunately nothing locks when in sync with the other 192
in fact that was my initial audio setup till i noticed one 192 did not sync anymore.
it all started when i was using my HD Native card and the strangest is that when i launch digitest included with pro tools hd 11, the results are showing an error message that he could not find any audio interface ---> even with the 192 that works fine.
EDIt i also have to say that, if i boot with HD11 on Mountain Lion usin the HD Native core card : sometimes the pro tools hd 11 does not find my working 192
My soundcloud page
Mac Pro 2x 2.66GHz 6-Core / 96 Go Ram / PE6R4-i - HD Native - Tempo Sata Pro 6Gb - PTHD : 10 / 11 /12 / Ultimate till 2022.5 - 192 i/o Digidesign - MTPAV - OSX : 10.4 / 10.5 / 10.6.8 / 10.8.5 / 10.9.5 / 10.11.6 / 10.13.6 / 10.14.6 - PowerMac G4 MDD / Pro Tools HD 5.3 / 6 / 7.4x / 8
Old 08-30-2020, 08:01 AM
JFreak's Avatar
If your working interface is not recognized the most likely cause is faulty DigiLink cable.
What I meant with the clocking test is even without connection to the core card, your interface should send 1X word clock out of the loop sync output so if you could get any external box lock to that signal we could rule something out of the equation.
But it seems you first need to try with a brand new DigiLink cable (and/or adapter)
Janne
Old 08-30-2020, 08:53 AM
well my fault, i guess i tried as i was discovering my actual problem and without cleaning all with the pro tools prefs helper.
I just gave it a try and all seems to be okay so far after several boots
Also : digitest is okay
My soundcloud page
Old 08-30-2020, 09:27 AM
JFreak's Avatar
Good to hear
Janne
Paste automation over multiple tracks issue, Fade Move Issue WinstonDeath Pro Tools 2020 1 04-09-2020 02:31 PM
PT 9.0.6 Start/Stop Issue and Plug-in Instrument Issue ZDF macOS 0 01-14-2013 02:47 PM
Some regions had invalid bounds... non-issue becoming a crash issue!!! krichu Pro Tools 9 3 12-11-2010 04:49 AM
Digi 002 Power Harness Issue or Firewire Chip Issue? Nish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 35 05-07-2010 01:25 PM
002 Console Issue, Faders Wont Move (grounding issue?) guitar486 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-01-2010 03:58 PM
