SMPTE Generator plug-in
Does any one know of
SMPTE Generator plug-in vst or rtas that can be used in Pro tools LE ? (without the DV toolkit) Thanx in advace !! P.S. Happy NY !! |
Re: SMPTE Generator plug-in
It seems nobody knows...well lucky me :)
A plug-in? I think you're asking for something that doesn't exist.
If you're trying to generate SMPTE from Pro Tools, the only way to go is a MIDI interface that supports MTC to SMPTE generation. |
Could you please elaborate? I have a MOTU MIDI Express XT that claims it "Converts MIDI Time Code to SMPTE time code ". I (or MOTU's tech support) have not been able to make this work. I only need to take MTC from tools and convert it to LTC SMPTE to drive a Neve fader automation system. No video or external MMC devices. Thanks for any help.
Actually, (not that this will do you any good!) Bob Lentini at SAW made a SMPTE MACHINE plugin, and it was frame accurate. EVERY TIME!!! BUT. And that's a BIG but. It was made specifically for SAW, and not a VST plug. But just so you know, it can be done.
Check M-audio for midi-smpte converters. Not mainstream anymore so you'll probably have to find one on Ebay. |
I do this with a MOTU MTP AV.
Hey Tom,
Could you please elaborate? I have a MOTU MIDI Express XT that claims it "Converts MIDI Time Code to SMPTE time code ". I (or MOTU's tech support) have not been able to make this work. I only need to take MTC from tools and convert it to LTC SMPTE to drive a Neve fader automation system. No video or external MMC devices. Thanks for any help. |
SMPTE LTC is audio signal, right? Even if its ugly audio signal from a musical point of view, its still data that is possible to generate by a plugin. Maybe the DAC would cause lots of distortion when presented with such a signal, but theoretically it should work.
So to reiterate. Is there a plugin? |
Back on topic. Sorry about the hi jack.
Sign up for all things....AWESOME! Kris May the music move you |
Yeah, Lentini is a real GAs to talk to. Quite a mind at work there, huh???
If push comes to shove, you could get a SMPTE genererator and actually "stripe" an audio track just like we used to do on analog multitrack tape, output it to whatever you're using as a synchronizer, and let Pro Tools be the "master synce source." But no. There is no existing "plugin." |
Plug-Ins gone bad... Signal Generator | Noiselab | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 07-29-2010 09:56 PM |
SMPTE Plug for 6.2.2LE | bopsi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-17-2003 10:22 AM |
generator plug sweeping | ThatHitSound | Tips & Tricks | 4 | 09-06-2003 11:56 PM |
SMPTE generator | kCmCg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-30-2003 08:37 PM |
Where to find a TDM plug-in generator ? | Sergent Pepper | Tips & Tricks | 7 | 06-01-2001 12:44 AM |
