Old 10-24-2012, 01:51 PM
The Brince The Brince is offline
Default reason 6.5.1 rewire problems
He everyone. I upgraded tot he new protools 10.3.2 and now i can not rewire reason 6.5.1 into protools. reason opens with my protools session and the rewire plug in shows up, but my issue is that they will not run together. If i wre to hit play on protools, reason wont play, vice versa. any body else having this issue or know what to do?
now, my protools 10 does rewire abelton with no problem so the issue has to be between reason and protools.
please let me know if you need more info
thank you everyone
Old 10-24-2012, 08:54 PM
Greg M Greg M is offline
Default Re: reason 6.5.1 rewire problems
This is a long shot, but are you sure you are running Reason "as Administrator"?
Greg
Intel i7 3930K, Gigabyte GA-X79-UP4 (rev 1.0), 32 GB Corsair Vengeance 1600 ram, EVGA Nvidea GT 720 TI video card, a Samsung 850 Pro (256 GB) OS drive, 2 Samsung 850 Pro's (512 GB) in externally mounted drive bays for session and sample storage, Win 10 Pro, PT Ultimate (Native)2019.10, HD Omni, HD I/O 16x16 .
Old 10-24-2012, 10:01 PM
yup. i open protools first. then reason. It worked before until i did the upgrade in protools 10.3.2. i noticed when i put reason in the insert and the rewire box pops up that the compare button is light up (blue) and it wont let me deselect it.
Old 10-25-2012, 01:58 AM
Bushpig Bushpig is offline
Brince,
I've occasionally had this issue with Reason 6.5, and the solution has usually been that for some unknown reason (d'ya see what I did there), Reason will revert to 64 bit operation and it needs to be in 32 bit mode to run alongside ProTools.
Locate the Reason app in your Applications folder and Get Info on it. You'll see a button for "Open in 32 bit mode".
That should sort the problem. Dunno why this happens, but it's rare enough for me to have forgotten the fix when it happened to me recently and I had to go look it up again.
Hope that helps.
Cheers
Steve Bush
www.music180.com/pros/5887
2 x Systems: MacPro 4.1 (Nehalem) 2.26 8 Core, OSX 10.6.8, PT10.2HD, 14 Gig RAM, PCIe HD3, 192's, Sync I/O, Midi I/O.
Old 10-25-2012, 05:12 AM
Smile Re: reason 6.5.1 rewire problems
oh wow. thank you so much. thats exactly what the problem was. YAY!!!
Old 11-02-2012, 02:44 PM
CygnusX-1Bk2 CygnusX-1Bk2 is offline
Originally Posted by Bushpig View Post
Brince,
Hope that helps.
Cheers
Steve Bush
I had this same problem when upgrading to PT 10. I ended up contacting Propellerheads support. Once he resolved the issue I saw that this info is on their page about running Reason with PT but only there and it wasn't exactly sticking out.
I will choose,
Freewill
http://jimdiazaudio.com/
Old 03-28-2013, 09:42 AM
dirtbag43 dirtbag43 is offline
Thanks Bushpig. So glad you shared this, you're saving so much frustration in the world. Have a great day!
Late-2012 Mac Mini i7 2.3 GHz
4GB RAM
OSX Mountain Lion 10.8.2
BLA 002R
PT 10.3.2
Old 07-02-2013, 10:33 PM
wedgewedge wedgewedge is offline
I love this forum. Thank you!
Mac Pro 3.2 Ghz Quad, OS 10.13.3, 48 G RAM, UA Apollo Duo, PT 12.8.3
Old 07-31-2013, 02:23 PM
hairdu44 hairdu44 is offline
Thanks Bushpig! Just saved me a LOT of headaches.
Old 09-29-2013, 11:14 PM
brian crain brian crain is offline
Hi everyone, I am faced with this problem as well but I cannot find a solution. Everything was working fine till last week until rewire decided to stop. I am using protools 8 and rewire 7 on Mac. I can open reason from protools but the do not go together. I have checked the Reasons application folder and it is in 32 bit!! Honestly, I do not know what to do.....I am completely stuck.
HTML code is On
Pro Tools 8.0.4 Rewire with Reason 5 Problems mexablcknesekid MIDI 0 09-07-2010 07:02 PM
reason 4 rewire to pro tools LE problems. johnny_law 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-28-2008 08:20 AM
reason 4 rewire to pro tools LE problems! johnny_law 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-28-2008 08:19 AM
Rewire/Reason problems - help please PeteRowden 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-24-2007 02:20 PM
REASON ADAPTED 2.5 & REWIRE PROBLEMS ***BBOY*** 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-10-2005 12:19 PM
