Eleven Rack Expression Pedal
Just saw this on my Facebook page and checked it out. Pretty pricey IMO, but definitely a step (no pun intended) in a good direction:
http://bit.ly/sw_EP11S
THoM Facebook |
Re: Eleven Rack Expression Pedal
Yeah I've seen this pedal before. I actually think it came out about a year ago or so but was only available direct from Mission. Its actually $10 cheaper if you buy it directly from them http://www.mission-engineering.com/M.../Products.html
Though it 'may' be cheaper from Sweetwater once shipping is figured in. EDIT: Never Mind, I was thinking of the original 11R Mission pedal (EP11) this one is the EP11-S
I'm curious as to how it works as a switch as well. IIRC, the original EP11 had no switch.
I don't understand how this would work with the current 11R.
Exactly.
The only thing I can think of is that the switch creates a short in the circuit. I will try an experiment to see if pulling out the expression pedal cable shuts off the wah. It might be specific to the "EP11" option in the 11Rack. Quote:
Alas, the 11R only has one expression pedal input, so there's no port on the 11R to hook that extra 1/4" cable to.
I think you need an external box to covert the toe switch to a MIDI CC. Or maybe someone jumped the gun and 11R mk11 will have two expression ports? I don't even see this switch option on the Mission site. |
It's fairly new, and again "Sweetwater Exclusive" whatever that means. But it is odd that it's not on mission's website. |
Yeah, I'd like to get to the bottom of this soon. I plan on buying a Mission pedal.
Since we're never going to get "expression pedal auto-engage" judging by how long that request has been on IdealStale, this two 1/4" plug seems to be one of the few options unless you buy a controller with built in foot pedals. The 11R guys did an excellent job on the user interface for this box. The only complaint I have is the engaging the Wah. They either need auto-engage, or they need to have at least 2 expression ports. |
I sent an email to both Sweetwater and Mission to get an answer on how this will work.
From Mission:
The Ep-11-S is designed to work with the Eleven Rack, but in conjunction with a midi foot controller such as the Voodoo Lab Ground Control Pro. Simply put, plug both outputs into the GCP, and then Midi into the Eleven Rack. http://www.sweetwater.com/store/detail/GControlPro/ .....meaning Sweetwaters sight is misleading |
Roland expression pedal not functioning properly with eleven rack | lbar11 | Eleven Rack | 9 | 03-16-2017 10:35 AM |
Eleven Rack and a BOSS FV-500-L expression Pedal ? ? ? | magicaldog | Eleven Rack | 12 | 01-15-2014 08:54 AM |
Using Ernie Ball Volume Pedal as WAH Expression on Eleven. ? Need your help fast! | awritersparadise | Eleven Rack | 18 | 11-15-2012 06:48 PM |
11 Rack & Expression Pedal as Wah and Multiple EFX | VOX59 | Eleven Rack | 10 | 11-20-2011 12:43 PM |
Exp pedal w/ Eleven Rack and 003 rack weirdness. | decayd | Eleven Rack | 1 | 08-07-2011 03:56 PM |
