Old 01-06-2004, 04:10 PM
mcconnellsteve mcconnellsteve is offline
Default splitting stereo tracks to mono -- audio quality?
if i split a stereo track into two mono tracks (panned hard left and right), should i hear a difference in quality? i tried this as an experiment for fun and i THINK i am hearing something different, but i'm not sure if i'm psyching myself into that or if there really is a difference.
on a related question -- let's say i had a stereo piano track that was recorded without compression and my only outboard compressor is a mono unit. would purists cringe if if i split the stereo track into two mono tracks and then processed each of them (individually) through the outboard mono compressor (recording them back in through two different mono tracks)?
thanks,
steve
Old 01-06-2004, 05:04 PM
where02190 where02190 is offline
Default Re: splitting stereo tracks to mono -- audio quali
It's then same two audio files, on two mono tracks instead of one stereo track. Make sure your pans are hard l/r.
Old 04-08-2023, 12:12 PM
Bossmatic Bossmatic is offline
Default Re: splitting stereo tracks to mono -- audio quality?
I have always wondered if you split the kick drums or bass, from stereo to mono, then only keep one of the mono tracks (deleting the stereo as well as the right mono track), keep only the left and center it. Do you loose any quality or richness or quality of the kick/bass?
Old 04-08-2023, 12:28 PM
its2loud its2loud is offline
Rules of audio
If you have one source (one microphone) feeding into a stereo track then your recorded signal is not stereo. It is just two files if mono audio
If you record with a stereo microphone onto a stereo track, each independent channel with have its own information depending on the pickup pattern of that mic. If you delete one channel after recording you will lose any different material recorded on that channel.
ie, if you have a stereo pair of microphones recording a piano (one side high, one side low) into a stereo track then delete one channel you will be missing a whole register of the piano.
If you have processed your mono bass to make it stereo (chorusing/delay) and then remove one channel, you will me missing any added treatment to the original mono signal.
Old 04-08-2023, 12:39 PM
K Roche's Avatar
K Roche K Roche is offline
thanks,
steve
"Something different" =I do not know, but you could reverse the polarity on one of the mono tracks and see if they null ...
Who cares what "purists cringe " at----- that is their problem ... Try it and see if you like the result ....
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 04-08-2023, 03:55 PM
thanks,
steve
First question; there should be no change in quality, but there MIGHT be a slight change in volume, depending on what Pan Law setting you use(which might be the "difference" you think you hear).
Second question-while I agree that you shouldn't care what others think, lets' dig a little deeper; What mono compressor are you talking about? If its some highly regarded classy piece of gear, the by all means try it and see(hear). If its some "budget" piece(like any of the 1176 clones for under $500), then I would skip the hassle and use a good plugin, which is likely to sound as good or better, while saving you the grief of dealing with the latency(just because you CAN do something, that doesn't mean you SHOULD do something)
re kick drum and bass, as those are mono signals, they belong on mono tracks(my opinion). Splitting out will change level, but should not change the sound in any other way(assuming no stereo processing)
Old 04-08-2023, 10:17 PM
JFreak's Avatar
JFreak JFreak is offline
Hi, welcome to the community.
I have always wondered why people send me stereo tracks of mono sources like kick and bass. Must be a Logic thing.
Janne
Old 04-09-2023, 08:45 AM
And Garage Band.....
Old 04-09-2023, 02:28 PM
It kinda drives me nuts a little when the term “stereo” is used to define all 2 channel audio files or tracks.
Specifically, Stereo is a two channel audio format that delivers different audio information on the left and right sides. Stereo audio mimics how you hear sound in the real world with your two ears.
Not particular from anyone in this thread, just in general. It’s a term that is often wrongly used incorrectly when describing two audio channels.
Old 04-09-2023, 03:16 PM
Ben Jenssen's Avatar
I think it's been obvious for years, and not going away, the phenomenon that young people are getting into audio production without understanding the basics of mono/stereo that its2loud mentions. And I think it comes from not experiencing much of the analog cabling, routing and setting up that older people have.
Splitting Stereo to Mono In SE jrubel24 Pro Tools SE and Essential (Mac) 1 08-09-2013 07:12 AM
Splitting Stereo to Mono with Playlists DonaldM Tips & Tricks 5 08-04-2013 08:34 AM
Stereo Audio Tracks playing back mono rtebel macOS 2 03-25-2012 09:43 AM
A question about mono/stereo plug ins on mono tracks. rockguitarist1255 Pro Tools 10 2 12-24-2011 07:33 PM
Mono audio tracks + stereo aux track = panning issues! Help please! shotgunjoe Pro Tools M-Powered (Win) 2 03-31-2011 03:07 PM
