Old 11-28-2023, 04:07 PM
ManhtnProjct ManhtnProjct is offline
Default Could not complete your request because magic ID does not match.
I have a session that will not open because:
"Could not complete your request because magic ID does not match."
This is the first time i've seen this error.
Anyone have experience with this?
2021 16" MBP M1 PRO - 1TB - 16GB
MacOS 12.6.7
Pro Tools Studio 2023.9
(2) UA Apollo 8 Quad
(1) UA Apollo 16 Quad
Old 11-29-2023, 07:46 AM
tope d's Avatar
tope d tope d is offline
Default Re: Could not complete your request because magic ID does not match.
Have you already tried opening a new Session and import the session data having issues?
https://avidtech.my.salesforce-sites...oting/en336321
Please let us know.
Thanks!
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 11-29-2023, 03:03 PM
Creating a new Session and trying to import session data results in the same error message.
MacOS 12.6.7
Old 12-03-2023, 01:32 AM
bradch00 bradch00 is offline
Possibly the session file itself is corrupted. Have you tried going to the latest backup and opening it?
Pro Tools, Studio One Pro
2022 Mac Studio M1 Max 64GB-1TB NVME
OWC Thunderbay Mini (4TB SSD)
OWC Express 4M2 (4 X 2TB)
Interface: Presonus Quantum
Presonus Faderport & Faderport 8
Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128
BM5A, KRK VXT4, Equator D5
2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig)
Old 12-03-2023, 08:57 AM
its2loud its2loud is offline
Limit the type of session data you’re trying import by starting out with just raw tracks, clips and audio. If that imports ok them increase the import options until you find where it falls down.
You might need to do this track by track.
Old 12-05-2023, 10:31 AM
It doesn't let you get that far. The error comes up right after you choose the session to import data from.
MacOS 12.6.7
Old 12-05-2023, 02:57 PM
marianna's Avatar
marianna marianna is offline
AFAIK you need to go back to a backup as that error is PT way of telling you the session doc is corrupt.
Check your preferences and make sure you have set it up to autosave every minute and keep the last 99 autosaves.
Marianna
Marianna Montague
Sr. Dir. CX and Community | Customer Advocate
[email protected]
cell +1 (813) 493-6800
AOL IM avidmarianna
Twitter Avidmarianna
We're Avid. Learn more at www.avid.com
Old 12-06-2023, 08:26 AM
The autosaves have the same issue. There must be a way to correct the magic id in the code of the session file.
MacOS 12.6.7
Old 12-07-2023, 10:55 AM
tope d's Avatar
I've started a support case for you under case 04723673 so this can be further investgated.
Thanks!
-Tope
www.topedomingo.com
Old 04-23-2024, 12:48 AM
Tobi Adam Tobi Adam is offline
Hi everyone!
Any solution to this problem, or any knowledge what's causing it?
having the same problem here in the middle of a mix.
thank you
best Tobi
Could not complete Open Recent Session..magic ID does not match DC-Choppah Pro Tools M-Powered (Win) 1 01-14-2012 06:05 PM
Could not complete the Import Audio command because magic ID does not match ronfinch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-21-2010 02:32 PM
"magic ID does not match"?!?! test tube AUDIO 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-26-2005 01:23 AM
"Could not complete the open the session command because Magic ID does not match." willyrmc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-10-2003 01:47 PM
Magic ID does not match...!?!?!?!?! tomcat Pro Tools TDM Systems (Mac) 4 12-11-2001 01:26 AM
