Aux not receiving bus signal [Solved]
I'm sending an audio track to bus 3. An aux track has its input set to bus3 and its output sent to the main outputs.
Why isn't the signal coming through the aux though; why aren't my meters moving in the aux track? View a screenshot of my I/Os by clicking here at Dropbox. Last edited by arturoinletto; 01-14-2014 at 07:33 PM. |
Re: Aux not receiving bus signal
Hi
Cant see any screenshot but try and default ALL your i/o settings and see if that helps anything. Under setings and I/O and default all in out aux etc and try again Best of Luck Christopher
Silly me! I had the level turned all the way down on the send to bus 3!
Not receiving much signal from audio on faders | remusjacobs | macOS | 0 | 02-17-2012 07:34 AM |
Mbox (3G) is receiving signal, making white noise, and clipping while sitting idle. | schumann1000 | Pro Tools M-Powered (Win) | 1 | 06-06-2011 11:44 AM |
MIDI PT8 LE not receiving input signal | Recloose | MIDI | 3 | 09-02-2009 07:03 PM |
VIs receiving patch changes | poodlebuild | Virtual Instruments | 13 | 07-05-2007 04:31 PM |
SOLVED>>Need HELP, SUPER ASAP.< |
audioindo | Pro Tools TDM Systems (Mac) | 18 | 04-21-2007 05:43 AM |
