Dual Monitor stretching problem bug
I have been running PT 10.1.2 on Windows 7 x64 and its been working well with my dual monitor setting. I have the monitors set to stretch the desktop across the two monitors, horizontally.
I tried to install PT 10.2 on two different occassions and each time I have the same problem. When I when I open PT, I am able to get it to span the two monitors correctly but the Mix and Edit windows don't work correctly. The Edit window opens on the left monitor and the Mix window opens on the right monitor. When I open the Mix window it cannot be stretched to right monitor and the Edit window cannot be stretched to the left window. I have been running PT 9 (all versions) and PT 10 (all previous versions) without any problems. This only happens with PT 10.2. Due to installing and unistalling this with the same results each time, this sounds like a bug. Is anyone else experiencing this? Thanks Kevin Windows 7 x64 Pro Tools 10.01.2 Intel Core 2 Quad Q9550 Yorkfield 2.83GHz 12MB L2 Cache LGA 775 95W Quad-Core Processor ASUS P5Q LGA 775 Intel P45 ATX ICH10R Mushkin 8 GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit PNY NVidia Quadro FX580 Motu HD 192 audio interface Mbox, version 3 Midiman Midisport 8x8/S USB connection 4 Seagate/Maxtor SATA 7200 rpm hard drives Frontier Designs Alpha Track MIDI controller iLoks: 1-iLok 1 version 1, 1- iLok version 2 Dual 19" widescreen monitors All hardware devices are using up to date drivers unless specified. |
Re: Dual Monitor stretching problem bug
It's a known and reported bug. Avid has commented on it as well I believe. Sure it will be addressed soon
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
It is rumored fixed for the next release.
Thanks for the responses, I didn't see this posted before. Hopefully the next patch is soon.
Thanks Kevin |
PT 7.0 Dual monitor problem | x.miguel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-30-2006 04:49 PM |
dual monitor problem | stickstome2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 03-25-2004 07:13 PM |
StRaNgE Dual Monitor Problem | Zetajazz44 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-19-2004 06:46 AM |
dual monitor problem . . . | seared music | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-16-2003 07:03 AM |
Dual Monitor Problem | Stu Barbour | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-19-2001 02:12 PM |
