Old 10-27-2005, 08:33 AM
gar_lei gar_lei is offline
Default Difference between Command 8 and ProjectMix IO???
Hello
Can anyone please tell me the difference between Command 8 and ProjectMix IO?
I'm using M-Powered Protools, thinking of getting this new toy here.
Thanks
Gary
Old 10-27-2005, 09:42 AM
silverlode silverlode is offline
Default Re: Difference between Command 8 and ProjectMix IO
ProjectMix I/O
-Control surface and audio in/out
-Has HUI mode, MCU mode, MIDI mode.
-Works well with...??? We don't know yet but it looks like it will work well with a wide variety of apps.
-Designed by M-Audio prior to Digidesign buyout.
-Has M-audio Firewire 1814 guts.
-Unknown build quality
Command|8
-Control surface only
-Has "Command|8 personality" mode, MIDI mode.
-Works great with ProTools...not so good with anything else.
-Excellent build quality
I'm using a lot more Logic and Reason these days than ProTools, so I'm thinking of unloading my Command|8 and possibly getting a ProjectMix instead. The Command|8 is really a great product...awesome build quality and great feel. But I need something that will work with Logic better. My Command|8 is in mint condition and less that year old. Let me know if you're interested.
Old 10-28-2005, 12:11 PM
Thank you for the explaination.
Can you tell me what's the MIDI mode?
and basically ProjectMix I/O is equivalent or somehw better then Digi002 Console?
8preamps VS 4preamps
Word clock
Price!!!
Gary
Old 10-29-2005, 01:12 AM
bb_aus bb_aus is offline
command 8 has 10bit faders, i believe the project mix only has 7bit faders
Old 11-01-2005, 08:36 AM
Hello
Both has 10 bits faders.
Old 12-10-2005, 05:40 PM
customdigi customdigi is offline
I just got my ProjectMix IO Friday...so far, so good. Up and running with PT 7 on my 15' powerbook 1.5ghz. OS 10.4.3.
As for the build quality, I would call it excellent. It is much larger and sturdier than I anticipated, and the control surface is quite intuitive even for a dummy like me.
I will be happy to answer any questions that I can...I realize that there isn't that much hands-on information about this gear just yet.
-Matt, Fort Lauderdale
Old 12-23-2005, 01:52 PM
toddm7 toddm7 is offline
????????? So the Project Mix works with regular pro tools, not just M-Powered???????
Thanks
HP Laptop
Old 01-01-2006, 02:20 PM
Yes, it works with all versions of Pro Tools that support HUI. PT 7 TDM, LE, and MP.
Old 02-14-2006, 11:56 PM
Re_Org Re_Org is offline
Hi, how do you connect it to your powerbook ? Firewire ? What system do you use ? I was looking for the ProjectMix for a Mpowered system and to add faders to my Digi 002 with PTools 7 when at home !
I would highly appreciate any informations...
Dom.
Dom
Les Tambours du Bronx
RE_ORG
Old 02-28-2006, 04:32 PM
GeneralChaos GeneralChaos is offline
It is worth noting that the control surface itself will work with all the versions of Pro Tools.
However, if you want to actually use the mic pres or any of the input channels (eg. use the PM I/O for the actual tracking process) then you have to use Pro Tools M-Powered 7.0 or above.
(Disclaimer: I do not actually own a PM I/O but from all the research that I have been doing on it, I am 99.9% sure that this is true)
Any difference besides color between D Command and D Command ES? diamondschwin Pro Tools TDM Systems (Mac) 10 03-12-2012 12:15 PM
Command Keyboard Focus mode ' E ' command bug ? vudoo Pro Tools TDM Systems (Win) 2 09-10-2009 05:49 AM
Projectmix or Command 8 GBProSound Pro Tools M-Powered (Win) 4 12-14-2007 03:27 PM
Difference between Digi002 Console and ProjectMix? gar_lei 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 11-28-2005 07:57 AM
ProjectMix i/o vs Command 8 for acontrol surface JonnyGinese 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-10-2005 06:22 AM
