Old 10-10-2011, 03:11 AM
jezzbo jezzbo is offline
Default confused using 11R mic input with Logic 9
Hi everybody.
Yesterday I tried to record some vocals via 11R mic input into Logic.
To bad I didn't succeed.
Recording the mic input in Protools does work.
(In Pro Tools I can simply select "mic" for input)
In Logic I can see the inputs of 11R (1->8)
And recording guitar is no problem. (input 1 for unprocessed sounds, input 3 for moddeled sounds)
I tested all other outputs to get the mic input but no signal.
I also tried putting the input selection on 11R to "mic"
But then the mic signal gets moddeled in 11R. (and I don't want that)
Basically I would like to record vocals straight to Logic.
Using 11R as a digital interface.
And at the same time record guitars (modelled via 11R) to Logic.
Anybody have an idea what I do wrong?
Thanks for your help.
Jesse
Old 10-10-2011, 04:02 AM
CoiLive CoiLive is offline
Default Re: confused using 11R mic input with Logic 9
I don't know what your problem can be. I also use Logic 9 and it works just fine:
Input 1: DI Guitar Track
Input 2: Microphone
Input 3: Guitar Modeled L
Input 4: Guitar Modeled R
(the rest I don't know by heart).
I do however have a problem sometimes and that is when I have the vocal track record enabled and then just start playing back the song. From that moment on I'm not able to hear the vocals anymore. But, if I have the vocal track record enabled AND also start recording I can hear the vocals just fine.
It is possible to record: Your DI guitar track, your vocals and you modeled guitar track at the same time. I do it all the time in Logic :)
Old 10-10-2011, 05:14 AM
OneStrat OneStrat is offline
I use a mic with Logic 9 and the 11R with no problem.
The unprocessed mic signal comes out of input 2 in Logic. Be sure to check the mic gain control on the 11R front panel. The signal can be quite low when the signal is not going through the rig. Also make sure the phantom power is on if you are using a condenser mic. If you select the mic as the rig input on the 11R, then the processed signal will come from input 3 and 4 in Logic.
Old 10-10-2011, 05:40 AM
thank you for your replies.
I'm gonna try it again this evening.
I'm glad to here that it is possible. I must have done something stupid.
I'll keep you informed.
Jesse
Old 10-10-2011, 05:42 AM
and what if you put software monitoring on? (press the small button "I" in the track, the one near the "R" for recording enable)
Old 10-10-2011, 06:50 AM
Hmmm, never though of that. Will give it a go and let you know :)
Update: Nope, that doesn't work.
Old 10-10-2011, 01:28 PM
Ok, tried it agian and recording works in Logic the way I want.
I don't know what I did wrong yesterday.
Thank you for your help!
Old 10-10-2011, 01:29 PM
I'm gonna try that (probably) tomorrow.
I'll let you know.
Old 10-16-2011, 12:06 AM
I finally had some time to try it.
Same result here.
Vocal record enabeled.
There are allready some vox on this track. And they get played, not the input.
Jesse
Confused by input latency in Pro Tools hollow Windows 11 02-12-2014 10:59 AM
PT 9.02 USB Input Setup -- Very Confused! snapperglubb macOS 1 11-19-2011 09:14 PM
Input to Logic from 192 interface danielclark Pro Tools TDM Systems (Mac) 4 08-12-2008 02:18 PM
HUI logic control, still confused Mullholland Pro Tools TDM Systems (Mac) 3 09-13-2002 02:08 PM
