Old 12-06-2011, 09:27 AM
Barry Johns Barry Johns is offline
Default 11R Tube Power Amp/Speaker Cab vs. Full Range Powered Monitor
I see some folks out there recommend a couple of different full range powered monitors to use with their Eleven Rack. Since this unit is so unique, I wonder if the typical thinking is best with it. I have my own thoughts about this question, but curious to see what others think.
Which is going to provide the best tone results from the Eleven Rack?
a. Tube Power Amp-Eleven Rack-2x12 or better
b. Powered Full Range Monitor
Traditional thinking would be (a), but the 11R is far from traditional.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 12-06-2011, 09:44 AM
Hotcrazyfruit Hotcrazyfruit is offline
Default Re: 11R Tube Power Amp/Speaker Cab vs. Full Range Powered Monitor
I have tried using my marshalls power amp section and cab as a form of loud speaker, but to be honest it sounded like garbage (weather that was the doing of myself or the setup, I have no idea). It was un-usably noisy. But sounds fantastic through my monitors
There are users who use the K-series from QSC
Nick
Core i7 920 OC'ed @ 4.0 GHz (200 X 20)
12 GB Patriot Viper Extreme
Asus P6T
OCZ Agility 64 GB SSD
Hitachi 1TB 32 MB HDD
WD Caviar Black 500GB
Saphhire HD 5850
3 x 20" monitors
Eleven Rack w/ ERXP
Fender Super Champ XD
Marshall JCM2000 DSL100 Silver Edition W/ Silver Jubilee Cabinet
Old 12-06-2011, 08:31 PM
Sofus Sofus is offline
as always it depends ...
for me, frfr all the way. i have the same sound and respons from studio monitors and stage monitors. i got decent results with a power amp and guitar cab, but i think this approach doesn't sound as natural as the frfr monitors.
one thing that has been a fight with myself is to get used to having a "recorded tone" over "amp in the room". when using frfr i usually explain it to others as playing behinde the console in a studio, it took some time to get used to for me.
Old 12-07-2011, 01:03 AM
Vhoot Vhoot is offline
I'm curious about the Kustom KPC12MP (http://www.musiciansfriend.com/pro-a...ource=3WWRWXGB).
This guys is having a descent success with his axe fx and it is only $119, too hard to believe.
Check out these videos.
http://www.youtube.com/watch?v=0GvlgT3myiI
http://www.youtube.com/watch?v=bURsElilGMw
http://www.youtube.com/watch?v=rqLFicVMBd4
http://www.youtube.com/watch?v=FQaALt0Hzlc
Old 12-07-2011, 06:15 AM
DAR Fritz DAR Fritz is offline
I've been using the Alto TS112a and so far they work pretty good plus they were inexpensive. I bought them at a Guitar Center store but I don't see them on their site. They may not be the best FRFR speakers out there but they work for me.
As with any FRFR speakers try and test them out before you buy.
Good luck!
Fritz
Old 12-07-2011, 09:46 AM
Good luck!
Fritz
how much were they? quite curious actually
Nick
Asus P6T
Saphhire HD 5850
3 x 20" monitors
Eleven Rack w/ ERXP
Old 12-07-2011, 10:52 AM
TieDyedDevil TieDyedDevil is offline
Traditional? <scratches head> Not in my world...
Look at it this way. The ER is designed to create great guitar tones for both live and direct-recording use.
Let's concentrate on direct-recording for a moment. You track with the ER, mix down, and play the mix through a good pair of monitors or headphones. As you listen, the ER guitar tracks sound just like a well-recorded amp (as they should)...
What happens if you run that same mix through a tube guitar amp and a 2x12? Doesn't sound right, does it...?
Here's another way of thinking about this...
You know that different guitar speakers make huge difference in the way a guitar amp sounds. That's because different speakers color the sound in their own way.
So lets say you have Celestion C30s in your 2x12... You turn off the cab emulation in the ER, dial up a Boogie patch, and... it sounds great. Just like you'd expect a Boogie to sound through C30s.
What happens, then, if you want to get get the sound of a Fender Twin through Jensen speakers? How do you set the ER to make your C30 2x12 sound like an open-back cab with a pair of Jensens? Dial in the Fender cab on the ER? Nope, that sounds like a mic'd Fender cab being played back through your C30 cab (reference the above re: playing a mixed track through your C30 cab).
So the short answer is: if you're really happy with your guitar cab and that's all you ever want to play through, go ahead. Just realize that you're sacrificing a lot of what the ER can do. (Also, your tube power amp is going to add its own coloration; you may end up thinking that your models sound a bit mushy if you push the tube amp...)
Old 12-07-2011, 12:38 PM
Jay_uk Jay_uk is offline
My 11r has not arrived yet, so i cant experiment. I have a Palmer pd-03 (it has cab emulation) and i,ve been thinking about where to place it for best results.
Option available are..
11r straight to Pro Tools
11r with tube amp (has simple effects loop no control)
11r with SS amp (has simple effects loop no control)
Where do you think i would get the best results ?
Cheers
Jay
Old 12-07-2011, 01:56 PM
Cheers
Jay
Could you explain a bit more? I don't understand what you're trying to ask...
Old 12-07-2011, 02:55 PM
First thanks for replying.
Well i,m not sure myself if i should be useing it with an 11r set up,
I,ve been using it purely as a power soak on my tube amp. Its a power soak/ combined speaker simulator, i just listed my gear to give an idea.
No need to give it too much attention "Tie", i dont wish to go off topic.
When i get the 11r i,ll try putting the Palmer in the SS amp head effects loop
and see what it sounds like.
Cheers
Jay
Five Inch Full Range Monitors GTBannah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-13-2007 05:42 PM
Moving large speakers(full range) NoRush General Discussion 2 02-04-2006 06:30 PM
Mid Range Tube Mics Straatocastoer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 34 04-19-2005 11:21 PM
OT: Frequency response on full range monitors. pindebraende 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-28-2003 09:27 AM
Disconneting Speaker from Tube Amp fifty8th1 Tips & Tricks 3 11-19-2000 12:06 AM
