Can someone please help me (midi)
I've opened up 3 different instruments in XPAND, i've sent them each to seperate midi channels, 1 to 3. I want to automate expression on one of them, so if i do it on one of them, it reacts to all of them!
This is very anyone and i would like to know how i can automate expression for the one i've selected. I mean i select the right instrument in the midi editor tab, then select expression and it writes the expression for not only that instrument i've selected, but all of them, why is this? Someone else could try this too, when i automate the midi volume, it reacts to it, but if i delete the automation i did, it doesn't react untill i adjust the fader a little bit, then it remembers?? Also, when loading a sound in XPAND for the first time, the sounds are loud, then when you move the midi fader a tiny bit, it then goes really low!??
PC - Intel i7 920 Quad - 9GB RAM - EX-58UD5 - 5 HDs - Windows 7 64bit Audio Interface - M-Audio Profire 610 Pro Tools - M-Powered 8.0.4 FL Studio - 9.0.3 Midi controllers - Behringer BCF 2000 - M-Audio Keystation 61es Dan-Jay |
dr 770 (boss dr rhythm 770) as midi controller/midi output to 11r midi input | yellow | Eleven Rack | 1 | 05-04-2012 03:33 PM |
003 midi ports not there in midi studio setup? Unable to record midi now? | TREBLEBLEED | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 12-22-2009 12:06 AM |
MIDI Questions On IMPORTING MIDI & Recording MIDI Pro Tools LE 7.4 | Michaeldante | MIDI | 3 | 03-27-2009 05:42 PM |
USB midi vs. din midi-(the old style midi connector) | Ling | Pro Tools M-Powered (Win) | 1 | 02-19-2009 02:15 PM |
Assigning MIDI sounds to MIDI controller and playing sounds with MIDI | lalalandguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-02-2009 12:52 PM |
