StudioVisionPro / ProTools
Quick question -
We've got some basic loops and little recorded audio stuff assembled along with a sequence in Studio Vision Pro. The sequences are to stay, as they will get more editing inside SVP. How can I get the "edl" for all the audio tracks out to ProTools? Thanks. -adam |
Re: StudioVisionPro / ProTools
Adam,
The easiest way is to bounce each track with all its edits from bar 1 to the end. Do this for all the tracks. Then you can import the newely bounced audio files into pro tools and place them all at bar 1. You can also give pro tools the same SMPTE start time as well as BPM that you have in the SVP session. I know it can be a little time consuming and takes up extra disk space but it will work. B Carter Digidesign |
Adam,
B is right on here; additionally, you can import the MIDI file from SVP into ProTools. This would give you a grid if your meter or tempo changes, and you could play the MIDI from PT (but not edit it, unless you have PT5). If you're using SampleCell TDM, this is especially nice. I'm finding I do this more and more, as mixing in PT is a lot more musical and intuitive. It is time-consuming, though. Maybe later revs of PT5 will get rid of these problems (I pray...) Jamshied |
changing from protools 8 audio only to protools 8 with video support | djkaz | macOS | 5 | 09-04-2013 04:00 PM |
ProTools Shortcut keys suddenly became disabled in ProTools LE 8.0.5? | jgbsound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-03-2011 01:08 AM |
Protools 8 LE/ Error 5000 / Protools freezes constantly HELP! | G ray | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-12-2011 07:09 PM |
Sending protools projects to other protools users online | kdtufan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-24-2008 07:18 PM |
setting record levels into ProTools with the intent of mixing in ProTools | Felix | Tips & Tricks | 507 | 02-05-2002 10:17 PM |
