Old 02-10-2007, 01:15 AM
sgladm sgladm is offline
Default Mbox 2 Pro in surround using other DAW?
Hello,
Does anyone know if the Mbox 2 Pro will support surround work (as an interface, if i'm using Logic)?
I see it has 6 outs, but 5 and 6 look shady to me.
Any thoughts on this?
Will I be able to plug outputs 1 through 6 directly to blue sky's bass management system and have 6 discrete stems?
Thanks.
SG
Old 02-10-2007, 07:51 AM
sunburst79 sunburst79 is offline
Default Re: Mbox 2 Pro in surround using other DAW?
I have no answer but this a very interesting question!
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 02-22-2007, 05:16 AM
bump anyone?
Old 02-22-2007, 07:07 AM
froyo froyo is offline
Hello. The answer is that you do have 8 discrete analog outputs. They have 4 balanced outputs (TRS) that they call Line Out 1 - 4. They have 4 unbalanced outputs (TS) which are the Monitor Out (LR) and the stereo 5/6 in one TRS connector. So yes you do have 8 discrete outputs, but only 4 are balanced. But you can feed the Blue Sky from the Mbox 2.
froyo
Old 02-22-2007, 10:21 AM
Cool thanks.
HTML code is On
Setting up MBOX 3 PRO for Surround barakka Post - Surround - Video 6 06-25-2015 07:33 AM
Mixing surround on New Mbox pro surroundnoob Post - Surround - Video 14 03-14-2011 05:21 AM
IMAC I7 + MBOX 2 PRO + Surround Bertolomi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-02-2010 08:52 PM
Mbox & surround jembert 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-05-2009 12:34 PM
Pro Tools LE Mbox 2 pro 5.1 surround? burma Post - Surround - Video 1 12-27-2006 04:50 PM
