Old 11-18-2012, 05:02 PM
Mykul0rr Mykul0rr is offline
Default PT 10.3.2 Major issues - help?
Hi All,
I don't often come on here for help...but I am stumped if I know what is happening.
Did an upgrade from PT10.2 to 3.2; prior to upgrade 10.2 was solid.
Did the uninstall of HD + drivers.
1. Tried to upgrade ilok - will not sync (upgraded driver & client )
2. Installed PT10.3.2 - all ok, so far.
3. Launched PT - loaded a previous session, which ran fine under 10.2
Complete crash with 20% CPU load.
Restarted - lost sync with audio interface
Re installed audio drivers, relaunched PT and loaded another session that was solid.
Massive latency issues; tried to correct - locked up, crashed and burned!
I have done this with another few attempts, using different sessions.
Best result was with a buffer of 256k, level4 streaming, short delay compen.
Soon as I try to change a RTAS instrument, crash.
It is massively unstable.
I have sent for help from ilok, to try and resolve the sync issue.
As for PT...well I'm up here looking for answers.
Should I revert to PT10.2?
Is 10.3.2 stable or are there many issues with it?
here's hoping someone can help
Regards
Old 11-18-2012, 06:07 PM
Default Re: PT 10.3.2 Major issues - help?
10.3.2 is solid here. It might help if you post a Sandra report so we have a clue about your setup. Then, if you save drive images, I would revert to a working setup(if you don't, then you NEED to get on board with imaging! Look into Acronis True Image or similar), or whatever it takes to get back to what you had that worked before(sometimes updates don't work as well as we'd like, so I NEVER install an update without saving an image first, and usually won't install an update unless it addresses something that I have actually had trouble with
Look at the top of the page for this link:
Help us Help You - READ THIS Before Posting!
Old 11-19-2012, 01:52 PM
Default Sandra Report
Thanks for your response...here's the Sandra Report
SiSoftware Sandra
ID
Host Name : Michael-PC
Workgroup : WORKGROUP
Computer
Model : OEM System Product Name
Serial Number : System Ser**********
Chassis : Desktop
Mainboard : ASUS P7F-C Series
Serial Number : 1112084********
BIOS : AMI (OEM) 0502 09/24/2010
Total Memory : 16GB DIMM DDR3
Processors
Processor : Intel(R) Xeon(R) CPU X3470 @ 2.93GHz (4C 8T 3GHz/3.59GHz, 2.4GHz IMC, 4x 256kB L2, 8MB L3)
Socket/Slot : FC LGA1156
Chipset
Memory Controller : ASUS Core (Clarksfield/Lynnfield) DMI 2x 2.4GHz (4.79GHz)
Memory Controller : Intel Xeon (Lynnfield) UnCore 2x 2.4GHz (4.79GHz), 2x 8GB DIMM DDR3 1.33GHz 128-bit
Memory Module(s)
Memory Module : Samsung M378B5273CH0-CH9 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5)
Video System
Monitor/Panel : LG L222W (1680x1050, 22.0")
Video Adapter : NVIDIA GeForce 9600 GT (64 SM4.0 1.63GHz, 512MB DDR3 1.8GHz 256-bit, PCIe 2.00 x16)
Graphics Processor
OpenCL GP Processor : NVIDIA GeForce 9600 GT (64SP 8C 1.63GHz, 512MB DDR3 1.8GHz 256-bit)
Compute Shader Processor : NVIDIA GeForce 9600 GT (64SP 1.63GHz, 512MB DDR3 1.8GHz 256-bit)
CUDA GP Processor : NVIDIA GeForce 9600 GT (64SP 8C 1.63GHz, 512MB DDR3 1.8GHz 256-bit)
Storage Devices
WDC WD10EALX-009BA0 (1TB, SATA600, 3.5", 7200rpm, 32MB Cache) : 932GB (C:) (E:)
SAMSUNG HD103UJ (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) : 932GB (D:) (F:)
WIBU - CodeMeter-Stick (41.2MB, USB1) : 39MB (H:)
Generic USB SD Reader (USB1) : N/A (J:)
Generic USB CF Reader (USB1) : N/A (K:)
Generic USB SM Reader (USB1) : N/A (L:)
Generic USB MS Reader (USB1) : N/A (M:)
ATAPI iHAS122 (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (G:)
Logical Storage Devices
System Reserved : 100MB (NTFS)
Backup (D:) : 466GB (NTFS) @ SAMSUNG HD103UJ (1TB, SATA300, 3.5", 7200rpm, 32MB Cache)
CODEMETER (H:) : 39MB (FAT32) @ WIBU - CodeMeter-Stick (41.2MB, USB1)
Hard Disk (C:) : 488GB (NTFS) @ WDC WD10EALX-009BA0 (1TB, SATA600, 3.5", 7200rpm, 32MB Cache)
Photos (E:) : 443GB (NTFS) @ WDC WD10EALX-009BA0 (1TB, SATA600, 3.5", 7200rpm, 32MB Cache)
Audio (F:) : 466GB (NTFS) @ SAMSUNG HD103UJ (1TB, SATA300, 3.5", 7200rpm, 32MB Cache)
Removable Drive (J:) : N/A @ Generic USB SD Reader (USB1)
Removable Drive (K:) : N/A @ Generic USB CF Reader (USB1)
Removable Drive (L:) : N/A @ Generic USB SM Reader (USB1)
Removable Drive (M:) : N/A @ Generic USB MS Reader (USB1)
Optical Drive (G:) : N/A @ ATAPI iHAS122 (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : ASUS 3420 LPC Interface Controller
LPC Legacy Controller 1 : T0 B3-55
Serial Port(s) : 2
Disk Controller : ASUS P55/PM55/3400 4 port SATA IDE Controller
Disk Controller : ASUS P55/PM55/3400 2 port SATA IDE Controller
USB Controller 1 : ASUS P55/PM55/3400 USB2 Enhanced Host Controller
USB Controller 2 : ASUS P55/PM55/3400 USB2 Enhanced Host Controller
USB Controller 3 : NEC Renesas Electronics USB 3.0 Host Controller
FireWire/1394 Controller 1 : VIA VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : KODAK ESP C315 AiO XPS (600x600, USB, Colour)
Printer : Adobe PDF Converter (4000x4000, Colour)
Peripherals
Network Services
Network Adapter : Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller (Ethernet, 100Mbps)
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 5.9
Old 11-19-2012, 02:54 PM
Unhappy Re: PT 10.3.2 Major issues - help?
I have run through a few more things...
Rechecked all the optimisation settings & startup items as per read me file for install.
Second, removed some unwanted programs.
Uninstalled PT 10.3.2 and put PT10.2.0 back
When I reloaded PT, issues still remained.
However, I believe there are some issues being caused by programs running n the background.
So, I ran a latency checker - which stated that my system was adequate. The latency was around 500micro sec, which I feel is too high. I remember it being around 300 micro secs.
So, this confirms my suspicions.
But identifying what it is, still eludes me.
I ran Ableton, which seemed fine.
But, in PT, the overriding issue is pops, click and massive interference with the smoothness that I am normally accustomed to.
Any additional help would be welcomed
Michael
Old 11-19-2012, 05:14 PM
Default Re: PT 10.3.2 Major issues - SOLVED
Managed to sort out the problem....
Microsoft sent a patch security update which turned back on several srvchost files...
This just sent the processor daft and kept interrupting flows.
Got a smart little program called Process Services which tells us some great info about what is really working in the background.
But, its now sounding sweet again!!
Shall I go for 10.3.2? Mmmmm
Old 11-19-2012, 05:23 PM
Originally Posted by Mykul0rr View Post
Yes, but save a drive image first. So if it fails, just resotre and be right back where you are now. FWIW, the Asus VIA firewire usually doesn't work with Pro Tools(but maybe you aren't using it)...
Major PT 11 Issues DonaldM Pro Tools 11 76 08-02-2013 12:33 AM
Major Freeze Issues Connor macOS 1 03-28-2012 11:56 AM
MAJOR ISSUES WITH 002 RIG!!! HELP!!!! andy1908 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-06-2007 04:30 PM
major, major issues satchvai 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 02-03-2006 01:10 PM
Having major PT issues. prismtheory Pro Tools TDM Systems (Mac) 12 05-16-2005 11:22 AM
