Old 06-07-2012, 04:49 AM
scottee scottee is offline
Default Balancing volume of a stereo track
Hello all
Can someone tell me how to adjust the volume of each side of a stereo track separately as one side is louder than the other? I am a complete newbie.
Pro Tools 10.3.6/11.0.1, M-Audio Fast Track Ultra 8R, Desktop - Intel i5 2.66GHz 1st gen, 12GB RAM, MS Windows 7 64-bit SP1, Laptop - Intel i7 2nd gen, 1.8GHz, 4GB RAM, MS Windows 7 64-bit SP1, Ibanez SZ720 Guitar, BOSS GT8 Guitar processor, 2 x KRK VXT4 monitors, KRK 10S sub, M-Audio Keystation 49e, M-Audio Microtrack II
Old 06-07-2012, 05:09 AM
PD-John PD-John is offline
Default Re: Balancing volume of a stereo track
Have you tried using clip gain to match the left/right levels?
You can also use the "Trim" plugin (in the Multi-Mono > Other menu) to adjust L/R levels - just be sure to unlink the channels on the plugin by clicking the button with the chain icon, near "Bypass".
Even otherwise, I'd recommend downloading and installing the free BlueCat bundle here:
http://www.bluecataudio.com/Products..._FreewarePack/
Along with the bundle comes a "Stereo Gain" plugin that allows you to individually adjust levels for left and right channels on a stereo track.
Old 06-07-2012, 05:21 AM
When I select the track and then select Clip/Clip Gain, I am presented with Bypass Clip Gain or Render Clip Gain which is greyed out. This makes no sense to me so I will download the BlueCat bundle and see how I go.
Thanks
Old 06-07-2012, 05:28 AM
Which one of the following should I download for Windows 7 64 bit SP1:
Win x64-DX / Win x64-VST
Old 06-07-2012, 05:34 AM
I have re-read your post and will try again.
Old 06-07-2012, 06:13 AM
Sorry, disregard the clip gain suggestion - when using clip gain on a stereo track it'll only change the level of both left and right at the same time...
The Trim or BlueCat plugins should be the easiest option. Or you can do it the long way by selecting the track, choosing Track > Split Into Mono, setting the levels right on the 2 mono tracks using clip gain, then selecting both tracks and dragging them back onto the stereo track. To use clip gain, click on the little fader icon at the bottom right corner of every audio clip. When you click it, your mouse should become a fader, and you can slide up or down to increase/decrease the level of that clip.
Old 06-07-2012, 10:47 AM
Rob_A Rob_A is offline
I've been splitting st track to mono, balance levels then re-combine in a stereo track again. Not sure if this is the correct way but it seems to work for me.
Cheers
Mani
Old 06-07-2012, 05:28 PM
Many stereo plugins allow for NOT ganging L&R. One of those would allow for turning up the output on one side to match levels.
Old 06-07-2012, 06:56 PM
Shan's Avatar
Shan Shan is offline
Originally Posted by scottee View Post
Hello all
Insert the multi-mono Trim plug-in, unlink, then adjust the gain to one side, or select Track > Split into Mono then adjust.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 06-11-2012, 04:46 AM
Thanks everyone for your suggestions. I ended up downloading the Blue Cat's Freeware Plug-ins Pack II AAX and used the Blue Cat’s Gain (Dual) and it was very easy.
Left/Right volume control on stereo track Don Geppert Tips & Tricks 18 01-20-2017 05:16 AM
Mono Aux to Stereo track, volume level compensation? JackCoghill Post - Surround - Video 7 02-12-2014 06:45 AM
Another output volume / balancing set up question Mickslick Eleven Rack 0 04-22-2011 06:40 PM
Adjusting Volume of Individual Sides of a Stereo Track mbyeates 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-26-2010 10:47 AM
Stereo audio track volume/pan question... Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 05-25-2004 01:33 PM
