Old 02-03-2011, 03:51 PM
mooge mooge is offline
Default Avid Mojo recognized by Mac, not Pro Tools??
Hi everyone. Having a strange issue with our Avid Mojo...
Avid Mojo recognized by Mac Pro (shows up in system profiler) but when I select "video out firewire" within Pro Tools (7.4.2cs4) a dialog window appears and says no recognized firewire device is attached. I have had this problem before about a year ago and can't remember what the fix was. I thought it could be the video file type, but I've tried various videos and either get the same message or "video out firewire" is greyed out and unavailable. Current video is a small test .dv file I use on everything. I have tried multiple Mojos and get the same results each time. Everything I have read or seen indicates I'm doing everything correctly... Any ideas?!?!?
Old 02-04-2011, 02:43 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
Default Re: Avid Mojo recognized by Mac, not Pro Tools??
Are you running any other firewire devices (this will cause the mojo to throw a tanty)? this is not allowed unless you have another firewire card to create another firewire bus
I seem to remember this happening to me (7.4.3 was a couple of years ago) occasionally.The mojo is not powering up properly. Disconnect the mains psu from the wall, re-power, then connect to the mac, then load PT. This went away with later software versions.
cheers
cheers
Mike Aiton BSc (hons)
Dubbing Mixer/Sound Designer
BAFTA member
IPS member
former Post Production Expert at www.pro-tools-expert.com
www.mikerophonics.com
Old 02-04-2011, 05:14 AM
diamondschwin diamondschwin is offline
Do you have the avid video engine installed?
Max Holland
Producer / Re-Recording Mixer
Nashville / NYC
MKD Creative
HOBO Audio
Old 02-04-2011, 05:36 AM
BradLyons BradLyons is offline
This was going to be my suggestion---have you installed any updates or new versions lately? The AVID video drivers can be VERY finicky so that might need to be re-installed
Thank you, Brad Lyons
GC PRO- Pro Accounts Manager
(404)844-9758
blyons@gcpro.com
www.theaudioprofessional.com
Old 02-04-2011, 01:33 PM
Thanks for replies!
No other firewire devices attached. Avid video engine installed (and re-installed). Re-booted... all the usual tricks.
Tried the exact same set-up on a rig running PT8 (only difference) and no problems - worked as it should.
Is there some driver I need or something? This is a head-scratcher for sure!
Thanks for any advice!
-Jon
Old 02-04-2011, 01:49 PM
Did you try the mojo power reset?
Repower it, then connect to the mac, them boot PT
used to work for me
cheers
cheers
BAFTA member
IPS member
Old 02-04-2011, 02:55 PM
Mojo Power Reset? Not sure what you mean by this... do you mean to simply unplug the AC, plug back in and re-connect to Mac or is there some hidden switch or trick that I'm missing?
Thanks!
Old 02-04-2011, 04:05 PM
mix109 mix109 is offline
Tried conecting the Mojo to another FW port?
If you have or can find any Avid System,perhaps reflashing it could make it work..
Old 02-05-2011, 02:54 AM
as written earlier - unplug mains from wall, wait 30s, reconnect to mojo, reconnect mojo to mac, boot pro tools
cheers
cheers
BAFTA member
IPS member
HTML code is On
PRO TOOLS 7.4 and AVID MOJO SET UP!!!! stereocilia Post - Surround - Video 2 03-16-2009 12:36 PM
Using Avid Mojo with Pro Tools 7 wallygrant Post - Surround - Video 7 01-07-2006 06:15 AM
can you use an avid mojo with pro tools 6.9 LE bowserlm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-19-2005 11:23 AM
Pro Tools TDM 6.6r2 for Avid Mojo on OS X Avid General Announcements 0 12-22-2004 06:04 PM
Pro Tools TDM 6.6 for Avid Mojo on OS X Avid Post - Surround - Video 0 10-29-2004 12:16 AM
